X
The Latest Oracle E-Business Suite Technology News direct from
Oracle E-Business Suite Development & Product Management
DSTv34 Timezone Patches Available for E-Business Suite 12.2 and 12.1
Elke Phelps
Product Management Director
The DSTv34 timezone upgrade is now available and certified with Oracle E-Business Suite Releases 12.2 and 12.1. Note that DST patches are cumulative and therefore include all previous Oracle DST updates.
How Does Oracle E-Business Suite Work Across Timezones?
Periodically, many countries or regions change their timezone definitions. In addition, and more frequently, they may switch to or from Daylight Saving Time or Summer Time.
If your Oracle E-Business Suite environment is configured to support doing business across multiple timezones, you need to keep your timezone definition files up-to-date by applying patches as described in this article. This will ensure that the times transactions take place are recorded correctly, and thereby meet applicable business and legal requirements.
Is My Oracle E-Business Suite Environment Affected?
When a country or region changes its timezone definitions or DST rules, your Oracle E-Business Suite environment will require patching if either of the following is true:
  • Your EBS environment is located in the affected country or region.
  • Your EBS environment is located outside the affected country or region, but you conduct business or have customers or suppliers there.
The following are major additions or changes in the DSTv34 timezones definitions compared to the previous release:
  • Brazil no longer observes DST (Previously scheduled for change 2019-11-03)
  • Palestine "springs forward" on 2019-03-30 instead of 2019-03-23
  • Metlakatla "fell back" to rejoin Alaska Time on 2019-01-20 at 02:00
  • São Tomé and Príncipe switches from +01 to +00 on 2019-01-01
  • Qyzylorda, Kazakhstan moved from +06 to +05 on 2018-12-21
  • New zone Asia/Qostanay because Qostanay, Kazakhstan didn't move
  • Metlakatla, Alaska observes PST this winter only
What Patches Do I Require?
The following MOS note identifies the various components in your Oracle E-Business Suite environment that may need DST patches:
Note: Proactive back ports of DST upgrade patches to all Oracle E-Business Suite tiers and platforms are not created and supplied by default. If you need this DST release and an appropriate patch is not currently available, raise a service request through support providing a business case and your version requirements.
What if I Do Not Apply the Relevant Patches?
If you do business with a country or region that has changed its timezone definitions, and record a transaction that occurs at the boundary between the “old” and the “new” time, then the transaction may be recorded incorrectly. Specifically, that transaction's timestamp may be out by an hour.
References
Related Articles
Be the first to comment
Comments ( 0 )
Please enter your name.Please provide a valid email address.Please enter a comment.CAPTCHA challenge response provided was incorrect. Please try again.
