The DSTv33 timezone upgrade is now available and certified with Oracle E-Business Suite Releases 12.2 and 12.1. Note that DST patches are cumulative and therefore include all previous Oracle DST updates.
How Does Oracle E-Business Suite Work Across Timezones?
Periodically, many countries or regions change their timezone definitions. In addition, and more frequently, they may switch to or from Daylight Saving Time or Summer Time.
If your Oracle E-Business Suite environment is configured to support doing business across multiple timezones, you need to keep your timezone definition files up-to-date by applying patches as described in this article. This will ensure that the times transactions take place are recorded correctly, and thereby meet applicable business and legal requirements.
Is My Oracle E-Business Suite Environment Affected?
When a country or region changes its timezone definitions or DST rules, your Oracle E-Business Suite environment will require patching if either of the following is true:
- Your EBS environment is located in the affected country or region.
- Your EBS environment is located outside the affected country or region, but you conduct business or have customers or suppliers there.
The following are major additions or changes in the DSTv33 timezones definitions compared to the previous release:
- Most of Chile now ends DST on the first Saturday in April (starting 6-Apr-19) and resumes DST in September.
- Morocco switches to permanent +01 on 2018-10-27.
- Volgograd moves from +03 to +04 on 2018-10-28.
- Fiji ends DST 2019-01-13, not 2019-01-20.
- Use of “PST” and “PDT” for Philippines time.
What Patches Do I Require?
The following MOS note identifies the various components in your Oracle E-Business Suite environment that may need DST patches:
- Complying with Daylight Saving Time (DST) and Time Zone Rule Changes in Oracle E-Business Suite Release 12.x (MOS Note 563019.1)
What if I Do Not Apply the Relevant Patches?
If you do business with a country or region that has changed its timezone definitions, and record a transaction that occurs at the boundary between the “old” and the “new” time, then the transaction may be recorded incorrectly. Specifically, that transaction’s timestamp may be out by an hour.
References
