We seem to have had a spate of problems reported to Oracle Support recently whereby there have been some odd issues with session handling in EBusiness Suite 11i. In most cases, the problem was seemingly introduced after applying an ATG RUP patchset
I won’t trouble you with the specifics of the problems, as it was quickly identified that the issue was only occurring when the profile option “Self Service Personal Home Page mode” (APPLICATIONS_HOME_PAGE) was set to “Personal Home Page” (PHP) rather than “Framework Only” (FWK)
Using “Personal Home Page” has not been recommended nor supported for a considerable time now, as documented in these Metalink notes:
- About Oracle Applications Technology 11i.ATG_PF.H Rollup 4 (RUP 4) (Metalink Note 365228.1)
Is The ‘Personal Home Page’ Mode Supported In Oracle 11i Applications? (Metalink Note 368628.1)
Even if this profile option is set correctly at SITE level, it could be set incorrectly for specific users, so recommend you use the following SQL to quickly confirm that you are only using the FWK setting in all cases
If you do find anyone still using “Personal Home Page”, my recommendation is to immediately switch to the “Framework Only” setting to ensure your environment is running a supported value and conforms to security best practice
