Oracle Active Data Guard 12.1.0.2 is now certified with Oracle E-Business Suite 12.2.  This certification supports the ability to offload some production reporting from your production EBS 12.2 environment to an Active Data Guard instance. For example, you can use Oracle Discoverer and Concurrent Manager to run selected reports against an Oracle Active Data Guard physical standby database instance.
Detailed steps for setting up Active Data Guard 12.1.0.2 with Oracle E-Business Suite 12.2 are provided in the following My Oracle Support Note:
Active Data Guard ADG 12.1.0.2 + EBS
In addition to Discoverer and Concurrent Manager, you may have other reporting tools that you would like to use with the Oracle Active Data Guard database instance.  In general, you should be able to use the reporting tool if it does not require write access to the Active Data Guard instance.
Pending Certifications
This certification covers non-RAC instances only.  Updates for environments that use Real Application Clusters are still pending.
Oracle’s Revenue Recognition rules prohibit us from discussing certification and release dates, but you’re welcome to monitor or subscribe to this blog. I’ll post updates here as soon as soon as they’re available.
Related Articles
