(17-JUL-2020 Update:  The JRE 1.8.0_261 update is available with Patch 31311324)
We are pleased to announce that the Java Runtime Environment (JRE) 1.8.0_261 (8u261) on the JRE 8 codeline is now certified with Oracle E-Business Suite Releases 12.1 and 12.2.  This update is available with Patch 31311324.
This article answers some questions you may have on the subject.
Is it a requirement to use Java Web Start with this JRE update?
While it is not a prerequisite to use Java Web Start for this latest Java CPU, please take another note of our previous guidance about moving to Java Web Start right away, and particularly ahead of September 2020.
You should uptake this latest Java CPU regardless of whether you are currently using Java Web Start or Java Plug-in on your client tier.
Note:  September 2020 is an important deadline for you if you are still using the Java Plug-in. Oracle Java team’s plans to continue shipping the components required to launch Java applets on Internet Explorer 11 using Java Plug-in, and Oracle E-Business Suite Support team’s ability to help customers still using Java Plugin are confirmed only through September 2020. Beyond this date, it will be increasingly complicated to receive any new fixes for Oracle E-Business Suite issues specific to Java Plug-in.
How do I get support adopting this latest Java CPU?
If you are using Java Web Start and require assistance with applying this CPU, you can log a service request for assistance from the Java Support organization.
For those of you still in transition to Java Web Start, refer to the following in our recently published My Oracle Support note, FAQ: Essentials of Java Usage in Oracle E-Business Suite (MOS Note 2510500.1):
Where are the JRE 8 requirements for EBS documented?
Full requirements for using Oracle E-Business Suite Releases 12.2 and 12.1 with JRE 8 are listed in the following documents:
Are there special considerations for running JRE 8 on Mac?
JRE 8 can be used with Oracle E-Business Suite 12.2 and 12.1 on Mac. To see a list of browsers and JRE versions certified on different macOS versions, refer to:
References
Related Articles
