Contributing Authors: Robert Farrington and Elke Phelps
We are pleased to announce that the Java Runtime Environment (JRE) 1.8.0_241 (8u241) on the JRE 8 codeline is now certified with Oracle E-Business Suite Releases 12.1 and 12.2.
This article answers some questions you may have on the subject.
Should I use Java Web Start or the Java Plug-in with this JRE update?
While we strongly recommend that you migrate to Java Web Start now, using Java Web Start is not a prerequisite for using this Java CPU. You should uptake this latest Java CPU regardless of whether you are currently using Java Web Start or Java Plug-in on your client tier.
How do I get support adopting this latest Java CPU?
If you are using Java Web Start and require assistance with applying this CPU, you can log a service request for assistance from the Java Support organization.
For those of you still in transition to Java Web Start, refer to the following in our recently published My Oracle Support note, FAQ: Essentials of Java Usage in Oracle E-Business Suite (MOS Note 2510500.1):
Where are the JRE 8 requirements for EBS documented?
Full requirements for using Oracle E-Business Suite Releases 12.2 and 12.1 with JRE 8 are listed in the following documents:
- Using Java Web Start with Oracle E-Business Suite (MOS Note 2188898.1)
- Deploying Sun JRE (Native Plug-in) for Windows Clients in Oracle E-Business Suite Release 12 (MOS Note 393931.1)
Are there special considerations for running JRE 8 on Mac?
JRE 8 can be used with Oracle E-Business Suite 12.2 and 12.1 on Mac. To see a list of browsers and JRE versions certified on different macOS versions, refer to:
Oracle E-Business Suite Release Notes Release 12 for macOS (OS X) (MOS Note 1533334.1)
References
- FAQ: Essentials of Java Usage in Oracle E-Business Suite (MOS Note 2510500.1)
- Upgrading JRE Plugin with Oracle Applications R12 (MOS Note 393931.1)
- Recommended Browsers for Oracle Applications 12 (MOS Note 389422.1)
- Oracle E-Business Suite Release Notes Release 12 for macOS (OS X) (MOS Note 1533334.1)
