Java logoWindows and Mac-based desktop clients connecting to the E-Business Suite can use the Java Runtime Environment (JRE) plug-in to run Forms-based components.  JRE 7 was certified with EBS 11.5.10.2, 12.0, and 12.1 in 2012.  As of today, the latest available version is JRE 1.7.0_21 for Windows clients and for Mac clients.  All new JRE releases on the 1.6 and 1.7 codelines are automatically certified with EBS on the day of their release.  If you’re reaching this article via a search engine, please check My Oracle Support or the Certifications summary for the latest desktop version available.
Java (JDK) 7 is now certified for E-Business Suite 12.0 and 12.1 application and database tier servers.  For instructions on upgrading your EBS 12.x environments, see:
The Java version currently in your environment
Oracle E-Business Suite Release 12 Rapid Install delivers the following Java SE Development Kit (JDK) Versions for use by Oracle E-Business Suite:
Release 12.0.x
    • Java SE Development Kit (JDK) Version 5.0 on the application tier
    • Java SE Development Kit (JDK) Version 1.4.2 on the OracleAS 10g 10.1.2 application tier hosting Forms and Reports services
    • Java SE Runtime Environment (JRE) Version 5.0 on the database tier
Release 12.1.x
    • Java SE Development Kit (JDK) Version 6.0 on the application tier
    • Java SE Runtime Environment (JRE) Version 6.0 on the database tier
You can now upgrade to the newer Java 7.0 Update on all EBS application tier and database tier nodes. Please note that the JRE 7.0 upgrade on the database tier is independent from the others. But if the application tier nodes are planned to be upgraded to Java 7.0, the same upgrade in the OracleAS 10.1.2 ORACLE HOME must be planned together.
Implications of Java 6 End of Public Updates for EBS Users
The Support Roadmap for Oracle Java is published here:
The latest updates to that page (as of Sept. 19, 2012) state:
Java SE 6 End of Public Updates Notice
After February 2013, Oracle will no longer post updates of Java SE 6 to its public download sites. Existing Java SE 6 downloads already posted as of February 2013 will remain accessible in the Java Archive on Oracle Technology Network. Developers and end-users are encouraged to update to more recent Java SE versions that remain available for public download. For enterprise customers, who need continued access to critical bug fixes and security fixes as well as general maintenance for Java SE 6 or older versions, long term support is available through Oracle Java SE Support .
What does this mean for Oracle E-Business Suite users?
EBS users fall under the category of “enterprise users” above.  Java is an integral part of the Oracle E-Business Suite technology stack, so EBS users will continue to receive Java SE 6 updates from February 2013 to the end of Java SE 6 Extended Support in June 2017.
In other words, nothing will change for EBS users after February 2013.
EBS users will continue to receive critical bug fixes and security fixes as well as general maintenance for Java SE 6. These Java SE 6 updates will be made available to EBS users for the Extended Support periods documented in the Oracle Lifetime Support policy document for Oracle Applications (PDF):
  1. EBS 11i Extended Support ends November 2013
  2. EBS 12.0 Extended Support ends January 2015
  3. EBS 12.1 Extended Support ends December 2018
How can EBS customers obtain Java 6 updates after the public end-of-life?
EBS customers can download Java 6 patches from My Oracle Support.  For a complete list of all Java SE patch numbers, see:
Will EBS users be forced to upgrade to JDK 7 for EBS Servers?
No. This upgrade will be highly recommended but will be optional for EBS application tier servers running on Windows, Linux, and Solaris.  You can choose to remain on JDK 6 for the duration of your respective EBS Extended Support period.  If you remain on JDK 6, you will continue to receive critical bug fixes and security fixes as well as general maintenance for JDK 6.
Will EBS users be forced to upgrade to JRE 7 for Windows desktop clients?
No. This upgrade will be highly recommended but currently remains optional. JRE 6 will be available to Windows users to run with EBS for the duration of your respective EBS Extended Support period.  Updates will be delivered via My Oracle Support, where you can continue to receive critical bug fixes and security fixes as well as general maintenance for JRE 6 desktop clients.
Coexistence of JRE 6 and JRE 7 on Windows desktops
The upgrade to JRE 7 is highly recommended for EBS users, but some users may need to run both JRE 6 and 7 on their Windows desktops for reasons unrelated to the E-Business Suite.
Most EBS configurations with IE and Firefox use non-static versioning by default. JRE 7 will be invoked instead of JRE 6 if both are installed on a Windows desktop. For more details, see “Appendix B: Static vs. Non-static Versioning and Set Up Options” in Notes 290801.1 and 393931.1.
Applying Updates to JRE 6 and JRE 7 to Windows desktops
Auto-update will keep JRE 7 up-to-date for Windows users with JRE 7 installed.
Auto-update will only keep JRE 7 up-to-date for Windows users with both JRE 6 and 7 installed.
JRE 6 users are strongly encouraged to apply the latest Critical Patch Updates as soon as possible after each release. The Jave SE CPUs will be available via My Oracle Support.  EBS users can find more information about JRE 6 and 7 updates here:
The dates for future Java SE CPUs can be found on the Critical Patch Updates, Security Alerts and Third Party Bulletin.  An RSS feed is available on that site for those who would like to be kept up-to-date.
What will Mac users need?
Oracle will provide updates to JRE 7 for Mac OS X users. EBS users running Macs will need to upgrade to JRE 7 to receive JRE updates.
Will EBS users be forced to upgrade to JDK 7 for EBS application tier servers?
References
Related Articles
