We recently announced the availability of AD-TXK Delta 13. This is part two in a series of blog articles to highlight the Oracle E-Business Suite (EBS) System Schema Migration, a key new feature of AD-TXK Delta 13 and Oracle E-Business Suite Release 12.2.11.
What are the Requirements to Complete the EBS System Schema Migration?
There are four requirements to complete the EBS System Schema Migration as follows:
1. Apply AD-TXK Delta 13
The first requirement to complete the EBS System Schema Migration is to apply R12.AD.C.Delta.13 (Patch 32394134) and R12.TXK.C.Delta.13 (Patch 32392507).
2. Apply the EBS 12.2.11 Release Update Patch (RUP) or the EBS System Schema Migration Consolidated Patch
The second requirement to complete the EBS System Schema Migration is to apply EBS 12.2.11 (Patch 31856789) or if you are running EBS 12.2.3 through 12.2.10 you can apply the EBS System Schema Migration Consolidated Patch (Patch 31817501)
3. Update Your Custom Code with Mandatory Compliance Requirements
The third requirement to complete the EBS System Schema Migration is to update your custom code with mandatory compliance requirements.
There are 3 mandatory development standards for customizations to comply with in order to complete the EBS System Schema Migration. It is estimated that the number of customizations that fall into this category is very low.
Note: Applying the patches listed in requirements 1 and 2 will not impact your existing customizations.
4. Apply the EBS System Schema Migration Completion Patch
The fourth requirement to complete the EBS System Schema Migration is to apply the EBS System Schema Migration Completion Patch (Patch 32573930)
For more information, see the following: Oracle E-Business Suite Release 12.2 System Schema Migration (MOS Note 2755875.1)
How Can You Learn More About the EBS System Schema Migration?
Each of the four requirements to complete the EBS System Schema Migration will be described in detail in the next four blog articles in this series.
In addition to the upcoming series of blog articles on this topic, learn more about the EBS System Schema Migration by leveraging the following resources:
- Oracle E-Business Suite Release 12.2 System Schema Migration (MOS Note 2755875.1)
- FAQ: Oracle E-Business Suite Release 12.2 System Schema Migration (MOS Note 2758999.1)
References
- Applying the Latest AD and TXK Release Update Packs to Oracle E-Business Suite Release 12.2 (MOS Note 1617461.1)
- Oracle E-Business Suite Applications DBA and Technology Stack Release Notes for R12.AD.C.Delta.13 and R12.TXK.C.Delta.13 (MOS Note 2758994.1)
