Oracle WebCenter Portal 12.2.1.3 is now certified with Oracle E-Business Suite Release 12.2 and 12.1.3. WebCenter Portal 12.2.1.3 is part of Oracle Fusion Middleware 12c Version 12.2.1.3.
Oracle WebCenter Portal is part of Oracle WebCenter. Oracle WebCenter is an integrated suite of tools used to create web sites and portals. Applications adapters are also available.
Certified Platforms
Oracle WebCenter Portal is certified to run on any operating system for which Oracle WebLogic Server 12c is certified. For information on operating systems supported by Oracle WebLogic Server 12c and Oracle WebCenter Portal, refer to the ‘Oracle Fusion Middleware on WebLogic Server – System Certification’ in the Oracle Fusion Middleware Supported System Configurations.
Integration with Oracle WebCenter Portal involves components spanning several different suites of Oracle products. There are no restrictions on which platform any particular component may be installed so long as the platform is supported for that component.
Migrating to Oracle WebCenter Portal
Oracle Portal entered Sustaining Support on July 1, 2017. The terminal release of Oracle Portal was 11.1.1.6. You can still download existing resources for Oracle Portal such as documentation and patches, but no new updates will be created. You should consider migrating to Oracle WebCenter Portal for ongoing new features.References
- Using WebCenter Portal 12.2.1 with Oracle E-Business Suite Release 12.2 (Note 2307813.1)
- Using WebCenter Portal 12.2.1 with Oracle E-Business Suite Release 12.1 (Note 2307427.1)
- WebCenter Portal 12.2.1 Documentation
Related Articles
