I have being receiving queries about configuring Oracle E-Business Suite Integrated SOA Gateway (ISG). ISG provides REST and SOAP based web service interfaces for public integration APIs registered in Oracle Integration Repository. Here’s a quick video that walks through the configuration process:
- Tutorial on configuring Integrated SOA Gateway in Oracle E-Business Suite Release 12.1.3 (8 minutes)
What is in this tutorial?
In this tutorial, I follow the steps documented in Installing Oracle E-Business Suite Integrated SOA Gateway, Release 12.1.3 (MOS ID 556540.1). This is the main document which lists the required patches and steps to configure EBS R12.1.3 instance for Integrated SOA Gateway.
This tutorial has following major sections:
- Applying Patches
- Executing TXK script
- Enabling ASADMIN user
- Verifying ISG Setup
This tutorial talks about configuring ISG in single node of EBS R12.1.3. If your EBS R12.1.3 instance is configured with a load balancer, you will be required to perform additional steps mentioned in My Oracle Support Document 1081100.1.
References
- Installing Oracle E-Business Suite Integrated SOA Gateway, Release 12.1.3 (MOS 556540.1)
- Configuring Oracle E-Business Suite Integrated SOA Gateway Release 12.1.2 and Release 12.1.3 in a Multinode Environment (MOS 1081100.1)
- Oracle E-Business Suite Release 12.1.3 – Integration Products and Technologies Primer (MOS 1494997.1)
Related Articles
- August 2018 Update to Integrated SOA Gateway
- Tutorial: Publishing EBS 12.2 PL/SQL APIs as REST Services
- Configuring Integrated SOA Gateway in Multinode EBS Environments
