Introduction
Partitioning Workflow tables can improve the performance of Workflow Engine run-time processing. Partitioning a table creates the subset of table based on the specified column value. Workflow tables are partitioned based on ITEM_TYPE. The wfpart.sql script can be used to migrate the non-partitioned workflow tables into partitioned tables. When there is large volume of data, this will increase the performance as it will have to read through a particular set of data instead of the whole table.
Tables and Indexes
The wfpart.sql script partitions four Workflow tables and recreates the associated indexes as shown in below table.
| Table | Indexes |
| WF_ITEM_ACTIVITY_STATUSES | WF_ITEM_ACTIVITY_STATUSES_PK WF_ITEM_ACTIVITY_STATUSES_N1 WF_ITEM_ACTIVITY_STATUSES_N2 |
| WF_ITEM_ACTIVITY_STATUSES_H | WF_ITEM_ACTIVITY_STATUSES_H_N1 WF_ITEM_ACTIVITY_STATUSES_H_N2 |
| WF_ITEM_ATTRIBUTE_VALUES | WF_ITEM_ATTRIBUTE_VALUES_PK |
| WF_ITEMS | WF_ITEMS_PK WF_ITEMS_N1 WF_ITEMS_N2 WF_ITEMS_N3 |
Before running the partitioning script, take a back up of these four tables so that you can restore them in case the script fails.To run the script, you must have sufficient free space on the table and index table spaces. During the creation of the partitioned tables, the script requires slightly more disk space than the underlying tables, in the same table space where the underlying tables are located. Similarly, sufficient free space is required for the index table space.
Usage
The wfpart.sql script can be run using below commands.
Run the script using below commands
sqlplus apps/<apps_passwd> @$FND_TOP/patch/115/sql/wfpart.sql <fnd_user> <fnd_passwd> <apps_user> <apps_passwd> <ult_dir_location>
<fnd_user> – fnd product username. APPLSYS in this case
<fnd_passwd> – fnd product password. applsys by default
<apps_user> – user name for the APPS user
<apps_passwd> – password for the APPS user
<ult_dir_location> – a directory that is included in the UTL_FILE_DIR database initialization parameter.For example:
sqlplus apps/apps @wfpart.sql applsys apps apps apps /usr/tmp
It generates another script wfpart.sql in the utl directory location eg:/usr/tmp
Run the generated wfpart sql script using below command
sqlplus apps/<apps_passwd> @<ult_dir_location>/wfpart.sql <fnd_user> <fnd_passwd> <apps_user> <apps_passwd>
For example:
sqlplus apps/apps @/usr/tmp/wfpart.sql applsys apps apps apps
It gives the below message once the script is completed
“Post-install script completed, you may ignore error during create
Please recompile the invalid objects after executing this script”
Additional Resources
1. Refer to Partitioning Workflow Tables section in Oracle Workflow Administrator guide
