[Feb. 25, 12:40 PM Update: Removed incorrect references to RHEL 3, SLES 9, HP-UX 11.11, Solaris 8] We’re very pleased to announce the release of Oracle E-Business Suite Plug-in 4.0, an integral part of Application Management Suite for Oracle E-Business Suite.
The management suite combines features in the standalone Application Management Pack (AMP) for Oracle E-Business Suite and Application Change Management Pack (ACMP) for Oracle E-Business Suite with Oracle’s real user monitoring and configuration management capabilities. The features that were available in the standalone Application Management Pack and Application Change Management Pack for Oracle E-Business Suite are now packaged into the Oracle E-Business Suite Plug-in 4.0. The Oracle E-Business Suite Plug-in 4.0 is now fully certified with Oracle Enterprise Manager 11g Grid Control. This latest plug-in extends Grid Control with E-Business Suite specific management capabilities and features enhanced change management support. The Oracle E-Business Suite Plug-in is released via patch 8333939. For the AMP and ACMP 4.0 installation guide, see:
Oracle Enterprise Manager 11g Grid Control Support Application Management Pack 4.0 and Application Change Management Pack 4.0 for Oracle E-Business Suite are certified with Oracle Enterprise Manager 11g Grid Control Release 1 (11.1.0.1.0).
Built-in Diagnostic Ability Release 4.0 has numerous major enhancements that provide the necessary intelligence to determine if the product has been installed and configured correctly. There are diagnostics for Discovery, Cloning, and User Monitoring that will validate if the appropriate patches, privileges, setups, and profile options have been configured. This feature improves the setup and configuration process.
Enhanced ACMP Capabilities
Customization Manager
Multi-Node Custom Application Registration: This feature automates the process of registering and validating custom products/applications on every node in a multi-node EBS system.
Public/Private File Source Mappings and E-Business Suite Mappings: File Source Mappings & E-Business Suite Mappings can be created and marked as public or private. Only the creator/owner can define/edit his/her own mappings. Users can use public Mappings, but cannot edit or change settings.
Test Checkout Command for Versions: This feature allows you to test/verify checkout commands at the version level within the File Source Mapping page.
Prerequisite Patch Validation: You can specify prerequisite patches for Customization packages and for Release 12 Oracle E-Business Suite packages.
Destination Path Population: You can now automatically populate the Destination Path for common file types during package construction.
OAF File Type Support: Ability to package Oracle Application Framework (OAF) customizations and deploy them across multiple Oracle E-Business Suite instances.
Extended PLL Support: Ability to distinguish between different types of PLLs (that is, Report and Forms PLL files). Providing better granularity when managing PLL objects.
Enhanced Standards Checker: Provides greater and more comprehensive list of coding standards that are verified during the package build process (for example, File Driver exceptions, Java checks, XML checks, SQL checks, etc.)
HTML Package Readme: The package Readme is in HTML format and includes the file listing.
Advanced Package Search Capabilities: The ability to utilize more criteria within the advanced search package (that is, Public, Last Updated by, Files Source Mapping, and E-Business Suite Mapping).
Enhanced Package Build Notifications: More detailed information on the results of a package build process. Better, more detailed troubleshooting guidance in the event of build failures.
Patch Manager
Staged Patches: Ability to run Patch Manager with no external internet access. Customer can download Oracle E-Business Suite patches into a shared location for Patch Manager to access and apply. Supports highly secured production environments that prohibit external internet connections.
Support for Superseded Patches: Automatic check for superseded patches. Allows users to easily add superseded patches into the Patch Run. More comprehensive and correct Patch Runs. Removes many manual and laborious tasks, frees up Apps DBAs for higher value-added tasks.
Automatic Primary Node Identification: Users can now specify which is the “primary node” (that is, which node hosts the Shared APPL_TOP) during the Patch Run interview process, available for Release 12 only.
Setup Manager
Preview Extract Results: Ability to execute an extract in “proof mode”, and examine the query results, to determine accuracy. Used in conjunction with the “where” clause in Advanced Filtering. This feature can provide better and more accurate fine tuning of extracts.
Use Uploaded Extracts in New Projects: Ability to incorporate uploaded extracts in new projects via new LOV fields in package construction. Leverages the Setup Manager repository to access extracts that have been uploaded. Allows customer to reuse uploaded extracts to provision new instances.
Re-use Existing Extracts in New Projects: Ability to incorporate existing extracts in new projects via new LOV fields in package construction. Leverages the Setup Manager repository to access point-in-time extracts (snapshots) of configuration data. Allows customer to reuse existing extracts to provision new instances. Allows comparative historical reporting of identical APIs, executed at different times.
Support for BR100 formats: Setup Manager can now automatically produce reports in the BR100 format. Native support for industry standard formats.
Concurrent Manager API Support: General Foundation now provides an API for management of “Concurrent Manager” configuration data. Ability to migrate Concurrent Managers from one instance to another. Complete the setup once and never again; no need to redefine the Concurrent Managers.
Certified configurations The following Oracle Enterprise Manager Grid Control releases, Oracle E-Business Suite releases, and platforms are supported:
Oracle E-Business Suite Plug-in 4.0 requires Enterprise Manager 11g Grid Control Release 1 (11.1.0.1.0)
11i: Release 11.5.10 CU2 with ATG_PF.H RUP6 or higher
12.0: Release 12.0.4 with R12.ATG_PF.A.delta.6
12.1: Release 12.1 with R12.ATG_PF.B.delta.3
Certified Platforms and Releases
Linux x86 (Oracle Linux 4, 5); (RHEL 4, 5); (SLES 10)
Linux x86-64 (Oracle Linux 4, 5); (RHEL 4, 5); (SLES 10)
Certifications still underway The following certifications are still in progress:
Oracle Solaris on SPARC (64-bit) (9, 10)
HP-UX Itanium (11.23, 11.31)
HP-UX PA-RISC (64-bit) (11.23, 11.31)
IBM AIX on Power Systems (64-bit) (5.3, 6.1)
Oracle’s Revenue Recognition rules prohibit us from discussing certification and release dates, but you’re welcome to monitor or subscribe to this blog for updates, which I’ll post as soon as soon as they’re available. Upgrades from AMP & ACMP 3 This plug-in supersedes the Oracle Application Management Pack for Oracle E-Business Suite 3.1. An upgrade path to 4.0 is provided from 3.1 only. Therefore it is mandatory for the existing installations to be at the Application Management Pack for Oracle E-Business Suite 3.1 level before upgrading to 4.0. AMP & ACMP 4.0 run only with EM 11g, and vice versa If you’re running AMP or ACMP 3.1 on EM 10gR5 and upgrade to AMP/ACMP 4.0, you must upgrade to EM 11g. If you’re running AMP or ACMP 3.1 on EM 10gR5 and upgrade to EM 11g, you must upgrade to AMP or ACMP 4.0. Related Articles
Steven Chan was a Senior Director in the Oracle Applications Technology Group. He managed EBS technology stack certifications, ATG product management, ATG documentation and curriculum, and ATG Quality Assurance in the E-Business Suite Development division.
Steven joined Oracle in 1998. Steven retired from Oracle in 2019. Prior to joining Oracle, he held positions with IBM, Deloitte & Touche Consulting, and other software companies.
Steven is an Oracle ACE and a three-time recipient of the Oracle Applications User Group 'Ambassador of the Year' Award (2007, 2009, 2010). Steven received the Oracle Applications User Group Lifetime Service Award in 2011.
