There are a lot of tools and products in the Apps Division. Reviewing the suite sometimes feels like painting the Golden Gate Bridge — by the time you’ve finished, it’s time to start all over again.
By way of explanation, that’s why it’s somewhat of a surprise to see how far along the Oracle Applications Manager (OAM) has come since the last time I looked at it. It’s matured into a pretty impressive set of tools for Apps system administrators and DBAs.
A Toolkit for Sysadmins
The Oracle Applications Manager provides a set of tools for configuring your E-Business Suite environment (including tight integration with AutoConfig), monitoring the health of a running environment (as shown in the screenshot above), notifying you with alerts if performance metrics cross specified thresholds:
New Features for 11.5.10
The list of new features in the latest 11.5.10 release is impressively long:
- JServ Monitoring
- Business Flow monitoring
- Concurrent Processing Charts
- Forms Runaway Process monitoring
- Applications Dashboard
- Advanced Configuration wizards
- Host Based Service Management
- Monitoring Applications DBA Utility running jobs
- Patch History Database enhancements
- Patch Advisor InfoBundle and Patch Download from MetaLink
- Enhanced Patch Impact Analysis
- Restricted Mode Access
- Enhanced Navigation
- Single Sign-On 10g Integration
- Rule Based Tracing and Profiling Controls
- User Initiated System Alerts
- Client Side Advisor for diagnosing problems with end-user PC configurations
- Support Cart for sending reports to Oracle Support
- New Logging Management Interface in Oracle Applications Manager
- New Dedicated Security Page in the Applications Dashboard
- Page access tracking for Oracle Applications Framework pages
- Integration with Sign-on Auditing
Oracle Applications Manager is included in your E-Business Suite licencing, so you don’t have to wrestle with your Procurement department before getting started with it. Just install the latest patch and you’re off to the races.
References
- About Oracle Applications Manager Mini-pack 11i.OAM.H (Note 258330.1)
- E-Business Suite Lifecycle Management (OTN)
