Microsoft (MS) Edge has recently released versions 142.0.3595.65 and 142.0.3595.69. After upgrading to either of these versions, you may find that launching a web-based function from Oracle Forms applications or from non-Forms Java applets in EBS Release 12.2 or 12.1 no longer opens a new browser window or tab as expected.
These issues arise from an unexpected change in behavior introduced in Microsoft Edge versions 142.0.3595.65 and 142.0.3595.69.
Recommended Resolution
It is recommended if you are running either MS Edge Version142.0.3595.65 or 142.0.3595.69, upgrade to Microsoft Edge Version 142.0.3595.76 or later. For more information, refer to the following:
References
- Recommended Browsers for Oracle E-Business Suite Release 12 (MOS Doc ID 389422.1)
- Using Java Web Start with Oracle E-Business Suite (MOS Doc ID 2188898.1)
- MS Edge Security Update Causes EBS Forms Popup-Related Functions to Stop Working [ Microsoft Edge Version 142.0.3595.65 ] or Higher (MOS Doc ID 3110822.1)
