The latest Java Runtime Environment 1.6.0_181 (a.k.a. JRE 6u181-b10) and later updates on the JRE 6 codeline are now certified with Oracle E-Business Suite Release 12.1 and 12.2 for Windows-based desktop clients.
What’s new in this update?
This update includes an important change: the Java deployment technology (i.e. the JRE browser plugin) is no longer available as of the Java 1.6.0_171 release. It is expected that Java deployment technology will not be packaged in later Java 6 updates.
JRE 1.6.0_171 and later JRE 1.6 updates can still run Java content. These releases cannot launch Java.
End-users who only have JRE 1.6.0_171 and later JRE 1.6 updates — but not JRE 1.8 — installed on their Windows desktop will be unable to launch Java content.
End-users who need to launch JRE 1.6 for compatibility with other third-party Java applications must also install the October 2017 PSU release JRE 1.8.0_152 or later JRE 1.8 updates on their desktops.
Once JRE 1.8.0_152 or a later JRE 1.8 update is installed on a Windows desktop, it can be used to launch JRE 1.6.0_171 and later updates on the JRE 1.6 codeline.
How do I get help with this change?
EBS customers requiring assistance with this change to Java deployment technology can log a Service Request for assistance from the Java Support group.
All JRE 6, 7, and 8 releases are certified with EBS upon release
Our standard policy is that all E-Business Suite customers can apply all JRE updates to end-user desktops:
- From JRE 1.6.0_03 and later updates on the JRE 6 codeline
- From JRE 1.7.0_10 and later updates on the JRE 7 codeline
- From JRE 1.8.0_25 and later updates on the JRE 8 codeline
You do not need to wait for a certification announcement before applying new JRE 6, 7, or 8 releases to your EBS users’ desktops.
Effects of new support dates on Java upgrades for EBS environments
Support dates for the E-Business Suite and Java have changed. Please review the sections below for more details:
- What does this mean for Oracle E-Business Suite users?
- Will EBS users be forced to upgrade to JRE 7 for Windows desktop clients?
- Will EBS users be forced to upgrade to JDK 7 for EBS application tier servers?
This certification includes both the 32-bit and 64-bit JRE versions for various Windows operating systems. See the respective Deploying JRE documentation for your EBS release for details.
How can EBS customers obtain Java 6 updates?
Java 6 is now available only via My Oracle Support for E-Business Suite users. You can find links to this release, including Release Notes, documentation, and the actual Java downloads here:- All Java SE Downloads on MOS (Note 1439822.1)
Coexistence of multiple JRE releases Windows desktops
The upgrade to JRE 8 is recommended for EBS users, but some users may need to run older versions of JRE 6 or 7 on their Windows desktops for reasons unrelated to the E-Business Suite.
Most EBS configurations with IE and Firefox use non-static versioning by default. JRE 8 will be invoked instead of earlier JRE releases if both are installed on a Windows desktop. For more details, see “Appendix B: Static vs. Non-static Versioning and Set Up Options” in Notes 290807.1 and 393931.1.
What do Mac users need?
Mac users running Mac OS X 10.10 (Yosemite) can run JRE 7 or 8 plug-ins. See:
JRE (“Deployment Technology”) is used for desktop clients. JDK is used for application tier servers.
JDK upgrades for E-Business Suite application tier servers are highly recommended but currently remain optional while Java 6 is covered by Extended Support. Updates will be delivered via My Oracle Support, where you can continue to receive critical bug fixes and security fixes as well as general maintenance for JDK 6 for application tier servers.
Java SE 6 (excluding Deployment Technology) is covered by Extended Support until December 2018. All EBS customers with application tier servers on Windows, Solaris, and Linux must upgrade to JDK 7 by December 2018. EBS customers running their application tier servers on other operating systems should check with their respective vendors for the support dates for those platforms.
JDK 7 is the latest Java release certified with E-Business Suite 12 servers. See:
- Java (JDK) 7 Certified for E-Business Suite 12.0 and 12.1 Servers
- Java (JDK) 7 Certified with E-Business Suite 12.2 Servers
References
- Recommended Browsers for Oracle Applications 12 (MetaLink Note 389422.1)
- Deploying Sun JRE (Native Plug-in) for Windows Clients in Oracle E-Business Suite Release 12 (Note 393931.1)
