In my previous article “Java Caching for Oracle Applications 11i: Part 1” I talked about the basics of Java Caching and how it works conceptually.
mzJavaD1:
My original intention with “Part 2” was to discuss how to diagnose issues with Java Caching, but I got a bit carried away with scripts and the like so ended up creating some Metalink notes instead.
Diagnosing Database Invalidation Issues
Here’s the first one:
As it says on the tin, this note covers diagnosing issues with Database Invalidation.   The classic symptoms being that when Responsibilities are added to a user, they are not appearing immediately (but do after Apache is bounced).
Although the scripts are listed in the note, you can also download a soft copy via the link mentioned in the note.
Diagnosing Issues with Responsibility Assignments
This issue is not actually a Java Caching problem, but the symptoms initially look similar to those described above.  The key difference here is that the affected responsibilities still do not appear after Apache is bounced.  For details, see:
More on NoClassDefFoundErrors
This one seems to be a bit of a “phantom illness” as I have seen two or three customers hit this issue, but after following the Action Plan in the note the problem is not reproducible anymore.   Even more bizarrely, after reverting the changes introduced by the Action Plan, the problem doesn’t come back!    This one has piqued my interest, so if anyone out there has the same symptoms and can still reproduce the problem after reading the following note, then I would be happy for you to email me your SR number.
Hopefully you will find these notes useful towards understanding and diagnosing any Java Cache issues you find yourself facing.
Related
