X
The Latest Oracle E-Business Suite Technology News direct from
Oracle E-Business Suite Development & Product Management
E-Business Suite Certified with DB 11.2.0.2 on HP-UX Itanium and IBM AIX on Power
Steven Chan
Senior Director
As a follow-on to our previous certification announcement, Oracle Database 11g Release 2 (11.2.0.2) s now certified with Oracle E-Business Suite Release 12 (12.0.x and 12.1.x) and 11i (11.5.10.2 + ATG PF.H RUP 6 and higher) on the following additional platforms:
  • HP-UX Itanium (11.31)
  • IBM AIX on Power Systems (64-bit) (5.3, 6.1)
Oracle E-Business Suite Release 11i
This announcement for Oracle E-Business Suite R12 and 11i includes: Pending Certifications
  • Transparent Data Encryption (TDE) Tablespace Encryption
  • Other platform certifications are pending and awaiting the availability of this patchset on the platform, including:
    • HP-UX PA-RISC (64-bit)
    • Microsoft Windows Server (32-bit)
    • IBM: Linux on System z
  • 'Split tier' or 'database tier only' certifications on:
    • AIX 7 (R12)
    • HP-UX Itanium 11.31 (11i)
    • Microsoft Windows x64 (64-bit) (R12)
Oracle's
Revenue Recognition rules prohibit us from discussing certification and
release dates, but you're welcome to monitor or subscribe to this blog
for updates, which I'll post as soon as soon as they're available.
EBS 11i References EBS 12 References Related Articles
Join the discussion
Comments ( 8 )
  • M K Wednesday, January 5, 2011
    Is 11i (11.5.10.2 + ATG PF.H RUP 6 and higher) going to be certified with AIX 7.1
    I believe DB 11.2.0.1 is already certified
  • John Abraham Wednesday, January 5, 2011
    Hi M K -
    No, we don't have any plans to certify AIX 7 with EBS 11i which is now in Extended Support - we typically only undertake new OS certifications for releases that are in Premier Support, so only R12 is being considered/planned.
    rgds,
    John
  • Luis Otavio Thursday, February 17, 2011
    Hi
    Do you have any plans to certify EBS 11.5.10 and Oracle DB 10.2.0.4 running in HPUX 11.31 based 100% in Integrity/Itanium2 platform ?
    If not can we consider running EBS 11.5.10 in HPUX 11.31 (PA RISC ) and DB 10.2.0.4 in HPUX 11.31 ( Integrity/Itanium2) as a supported environment by Oracle ?
    Thanks in advance
  • Peter P. Shih Thursday, February 17, 2011
    For EBS11i, only the database tier is certified on HP-UX Itanium. There are no plans to support EBS 11i application tier on HP-UX Itanium.
    You can run EBS in a split-configuration with 11.5.10.2 (application tier) on HP-UX 11.31 (PA-RISC) and DB 10.2.0.4 on HP-UX 11.31 (Itanium). Note that this is 11.5.10.2 only (11.5.10 is not certified in this configuration).
    Also note that DB 10.2.0.4 is already in Extended Support. DB 11.1.0.7 and 11.2.0.1 are also currently certified for use on HP-UX Itanium 11.31 (database tier) with 11.5.10.2.
  • guest Tuesday, June 14, 2011
    is 11.5.10.2 certified with HP-UX 64bit ? if so from where can I download the software ?
  • Steven Chan Tuesday, June 14, 2011
    Hi, Guest,
    Yes, EBS 11i is certified on HP-UX PA-RISC (64-bit) (11.11, 11.23, 11.31). You can download 11.5.10.2 from My Oracle Support via Patch 3480000.
    Regards,
    Steven
    Is there no direct release for 11.5.10.2 on HP-UX 64bit ? should I only go via the upgrade method ?
    I actually need 12.0.4 for HP-UX 64bit. I could not find the s/w so was planning to upgrade from 11.5.10.2. Is there a better way to get 12.0.4 on HP-Ux 64bit ?
    Hi, Guest,
    Rapid Install releases of both 11i and 12.0.4 are no longer being distributed. I would recommend starting with the 12.1.1 Rapid Install and upgrading to 12.1.3. You can find the HP-UX PA-RISC (64-bit) media on eDelivery.oracle.com.
    Regards,
    Steven
Please enter your name.Please provide a valid email address.Please enter a comment.CAPTCHA challenge response provided was incorrect. Please try again.
