Hourglass icon
If your E-Business Suite Release environment is configured to support Daylight Saving Time (DST) or international time zones, it’s important to keep your timezone definition files up-to-date. They were last changed in June 2015 and released as DSTv24.
DSTv25 is now available and certified with Oracle E-Business Suite Release 12.2 and 12.1. The DSTv25 update includes the timezone information from the IANA tzdata 2015g.  It is cumulative: it includes all previous Oracle DST updates.
Is Your Apps Environment Affected?
When a country or region changes DST rules or their time zone definitions, your Oracle E-Business Suite environment will require patching if:
  • Your Oracle E-Business Suite environment is located in the affected country or region OR
  • Your Oracle E-Business Suite environment is located outside the affected country or region but you conduct business or have customers or suppliers in the affected country or region
The latest DSTv25 timezone definition file is cumulative and includes all DST changes released in earlier time zone definition files. DSTv25 includes changes to the following timezones since the DSTv24 release:
  • Africa/Casablanca
  • Africa/El_Aaiun
  • America/Montevideo
  • Asia/Pyongyang
  • Europe/Istanbul
  • Pacific/Fiji
  • Turkey
  • Asia/Istanbul
What Patches Are Required? In case you haven’t been following our previous time zone or Daylight Saving Time (DST)-related articles, international timezone definitions for E-Business Suite environments are captured in a series of patches for the database and application tier servers in your environment. The actual scope and number of patches that need to be applied depend on whether you’ve applied previous DST or timezone-related patches. Some sysadmins have remarked to me that it generally takes more time to read the various timezone documents than it takes to apply these patches, but your mileage may vary.
Proactive backports of DST upgrade patches to all Oracle E-Business Suite tiers and platforms are not created and supplied by default. If you need this DST release and an appropriate patch is not currently available, raise a service request through support providing a business case with your version requirements.
The following Note identifies the various components in your E-Business Suite environment that may need DST patches:
