If you are using Multi-Fund Accounting and trying to balance the Receivable Module with the General Ledger,  your reports may not balance as expected.
Definitely check if the mandatory profile Option “AR: ACTIVATE MULTI FUND ACCOUNTING EXTRACT” is set. See this document for more information on the profile option.  (Doc ID 1503451.1)
One of the issues that can occur:
The standard Reports such as AR Reconciliation Report and the associated Registers and Journals (example: Transaction Register, Transaction Journal) and Aging – 7 Buckets by Account Report are not balancing with the amounts that are existing in the General Ledger.
Review:
Process to follow for Fund Level Reconciliation between AR and GL in R12 (Doc ID 2030905.1)
The Multi-Fund Accounts Receivable (MFAR) Aging Report Does Not Balance To AR Reconciliation Report (Doc ID 1558026.1)
Another issue that can occur:
The Journal Entries Report is not displaying information in the actual Subledger (SLA) journals
Review:
AR: JOURNAL ENTRIES REPORT SHOW AR ACCOUNTS AND INSTEAD OF SLA ACCOUNTS (Doc ID 2547495.1)
