Monitor replication health, configure proactive alerts, analyze operational logs, and explore AI-assisted observability with Azure Monitor and Azure Log Analytics.
Introduction
When running business-critical workloads, knowing that data replication is running isn’t enough. How do you know your data is up to date, replication is healthy, or potential issues are detected before they impact your business?
For customers running Oracle GoldenGate on Oracle AI Database@Azure, these questions can now be answered directly within the familiar Azure monitoring experience. With Azure Monitor and Azure Log Analytics, customers can monitor replication lag, track Extract and Replicat health, visualize resource utilization, configure proactive alerts, and analyze operational events—all while leveraging their existing Azure monitoring tools and workflows.
In my previous blog, I introduced how customers can deploy and manage Oracle GoldenGate directly from the Azure portal. Now, let’s take the next step: monitoring, troubleshooting, and gaining deeper operational visibility into your GoldenGate deployments without leaving Azure.
In this blog, we’ll walk through configuring monitoring dashboards, setting up proactive alerts, and analyzing operational events with Azure Log Analytics. We’ll also explore how emerging AI capabilities, such as the Azure Copilot Observability Agent, could help simplify troubleshooting and accelerate incident investigations.
1. Understanding GoldenGate observability in Azure
Oracle GoldenGate on Oracle AI Database@Azure combines GoldenGate’s real-time replication capabilities with Azure-native resource management and monitoring experiences. The observability integration uses two important Azure Monitor capabilities.
Azure Monitor Metrics provides numerical, time-series measurements that help administrators monitor replication performance, process health, and deployment resource utilization.
Azure Monitor Logs and Log Analytics enable customers to collect and query supported diagnostic events, analyze operational activity, and correlate available information with other resources monitored in Azure. These capabilities complement the existing Oracle GoldenGate administration interfaces, which remain important for detailed process diagnostics, configuration, and replication management.
2. Monitor Oracle GoldenGate metrics directly from Azure
One of the most useful aspects of Azure Monitor integration is the ability to view GoldenGate deployment and replication metrics without leaving the Azure portal. Administrators can use Azure Metrics Explorer to visualize system utilization, replication latency, and process-health indicators.
Accessing GoldenGate metrics
To view the metrics associated with a GoldenGate deployment:
  1. Sign in to the Microsoft Azure portal.
  2. Navigate to Oracle AI Database@Azure.
  3. Select Oracle GoldenGate from the left navigation menu.
  4. Open the Oracle GoldenGate Deployments tab.
  5. Select the deployment you want to monitor.
  6. Expand Monitoring and select Metrics.
  7. Verify that the selected scope corresponds to your GoldenGate deployment.
  8. Select the GoldenGate Deployment metric namespace.
  9. Choose the metric, aggregation, and time range you want to analyze.
For example, selecting CPU Utilization displays CPU consumption trends for the deployment over the selected monitoring period.
Understanding GoldenGate Metrics in Azure Monitor
Oracle GoldenGate provides a comprehensive set of metrics through Azure Monitor, offering visibility into deployment resource utilization, replication process health, and replication latency. Customers can monitor infrastructure metrics such as CPU, memory, and storage utilization, track the health of Extract, Replicat, and Distribution Path processes, and analyze replication performance using Extract Lag, Replicat Lag, and Heartbeat Lag. Monitoring these metrics together helps administrators identify potential bottlenecks, distinguish infrastructure issues from replication delays, and proactively maintain replication health. For example, while Extract Lag may remain low, increasing Replicat Lag could indicate delays in applying transactions at the target. For the complete list of supported metrics, their definitions, and usage details, refer to the Oracle GoldenGate Azure Monitor documentation.
Building a GoldenGate monitoring dashboard
While Metrics Explorer is useful for investigating individual metrics, operational teams often need a consolidated view across multiple signals. Azure dashboards make it possible to combine selected GoldenGate metrics into a single monitoring experience.
For example, a GoldenGate operations dashboard could display:
  • Overall deployment health
  • Extract and Replicat health
  • Extract and Replicat lag
  • Heartbeat lag
  • CPU utilization
  • Memory utilization
  • File system usage
To create a dashboard, open Dashboard hub in the Azure portal, create a custom dashboard, and add the desired metrics tiles. Select the appropriate GoldenGate resource scope, metric namespace, and aggregation for each tile. A dashboard can also include other supported Azure resource metrics, making it useful for organizations monitoring databases and replication infrastructure together.
For production environments, consider creating separate dashboards for platform infrastructure and replication operations.
3. Configure proactive alerts for Oracle GoldenGate using Azure Monitor
Monitoring dashboards provide visibility into the current state of a replication environment, but administrators cannot continuously watch every metric.
For business-critical replication workloads, organizations need a way to detect and respond to issues proactively.Azure Monitor alerts allow administrators to define conditions against supported GoldenGate metrics and trigger notifications when those conditions are met. For example, an organization might want to receive an alert when replication lag exceeds its operational threshold or CPU utilization remains elevated for a sustained period.
How Azure Monitor alerts work
Azure Monitor alerting consists of three primary components:
1. Alert rule: Defines the resource, metric, and condition being evaluated.
2. Evaluation criteria: Specifies the threshold, aggregation, evaluation frequency, and lookback window.
3. Action group: Defines the notification channels or automated actions to execute when an alert fires.
An action group can deliver notifications through email, SMS, push notifications, and other supported channels. It can also integrate with services such as Azure Functions, Logic Apps, and webhooks.
Example: Creating a replication lag alert
Consider a customer with a requirement to maintain replication latency below 60 seconds. The operations team wants to receive an alert if Replicat Lag exceeds this threshold for a sustained period.
Let’s create an example alert policy.
ConfigurationExample value
ResourceGoldenGate deployment
MetricReplicat Lag
AggregationMaximum, where supported
OperatorGreater than
Threshold60 seconds
Evaluation frequency1 minute
Lookback window5 minutes
SeveritySev 2
Action groupGoldenGate Operations
These values illustrate an example operational policy. Customers should select thresholds and evaluation settings appropriate for their replication service-level objectives. Also, an aggregation window is not necessarily a continuous-duration condition. For example, using Maximum over five minutes can trigger on one qualifying measurement in that period. Administrators should validate the resulting alert behavior rather than assuming it means the threshold was exceeded continuously for five minutes.
Step 1: Create an Azure Monitor action group
Before configuring the alert, create an action group to define who should receive notifications.
  1. In the Azure portal, navigate to Monitor.
  2. Select Alerts.
  3. Select Action groups.
  4. Click Create.
  5. Select the subscription and resource group.
  6. Enter an action group name, such as GoldenGate-Operations.
  7. Open the Notifications tab.
  8. Select Email/SMS message/Push/Voice, as appropriate.
  9. Configure the email address of the operations team.
  10. Review and create the action group.
For this example, we’ll configure email notifications. You can also enable the common alert schema to standardize the payload delivered to downstream alert consumers.
Step 2: Create the GoldenGate metric alert
  1. Navigate to Azure Monitor → Alerts.
  2. Select Create → Alert rule.
  3. Under Scope, select the Oracle GoldenGate deployment.
  4. Under Condition, select the required GoldenGate metric from drop down.
  5. Configure the aggregation, operator, threshold, and evaluation settings.
  6. Under Actions, associate the GGS-Alerts action group.
  7. Under Details, enter a descriptive alert rule name.
  8. Select the appropriate severity.
  9. Review the configuration and create the alert.
For example, the rule could be named: GoldenGate-CPU_Util-High. When the configured condition is met, Azure Monitor generates an alert and invokes the associated action group.
Step 3: Validate the alert notification
After configuring the rule, validate that it behaves as expected. This is an important step before relying on alerts for production operations. In a test environment, generate an alert condition using a controlled and approved workload scenario, or use supported test functionality to validate notification delivery.
Check that:
  • The alert condition is evaluated correctly.
  • The alert appears in Azure Monitor.
  • The configured action group is invoked.
  • The operations team receives the notification.
  • The alert resolves when the configured recovery conditions are met.
A test notification can confirm that the action group works, but it does not by itself prove that GoldenGate metric evaluation and alert resolution are configured correctly.
Integrating alerts with existing operational workflows
Many enterprises already have established incident-management processes. Azure Monitor action groups allow GoldenGate alert notifications to participate in those processes through supported integrations. For example, an organization might use:
GoldenGate metric alert → Azure Monitor → Action Group → Logic App → Incident-management system
An alert could trigger an Azure Logic App that creates a support ticket, enriches the alert with contextual information, or sends a message to the appropriate operations channel. This can help teams establish a consistent response process across Oracle and Azure workloads.
Where automation is used to perform corrective actions, I recommend retaining appropriate approval and validation controls. For example, automatically restarting a Replicat process is not always the correct response to increasing lag. The root cause could involve target database constraints, workload characteristics, or replication configuration issues that require investigation.
4. Centralize GoldenGate Operational Events with Azure Log Analytics
While Azure Monitor provides visibility into GoldenGate replication performance and resource utilization, understanding operational events is equally important when troubleshooting issues or managing production environments. Azure Log Analytics enables customers to collect, query, and analyze supported Oracle GoldenGate diagnostic events alongside monitoring data from other Azure resources. This allows organizations to incorporate GoldenGate into their existing Azure operational monitoring workflows without maintaining separate tools for every monitoring task.
For example, administrators can investigate whether a GoldenGate deployment experienced configuration changes, critical events, or other operational activity during a period of replication degradation.
Azure Log Analytics uses Kusto Query Language (KQL) to explore and analyze collected data. Customers can also use the simplified query experience to filter and investigate events without writing queries manually.
Configuring Log Analytics for Oracle GoldenGate
Getting started involves two primary steps:
  1. Create a Log Analytics workspace in Azure to collect and analyze supported operational events.
  2. Enable diagnostic settings for your Oracle GoldenGate deployment and configure the workspace as the destination for diagnostic events.
To configure diagnostic settings, navigate to your GoldenGate deployment in the Azure portal and select Monitoring → Diagnostic settings. Create a diagnostic setting, select the supported audit category group, and configure the destination as your Log Analytics workspace. Oracle GoldenGate supports diagnostic event categories including creation, update, deletion, backup, restore, critical, and informational events. These help provide visibility into supported resource lifecycle and operational activities. For complete configuration instructions, refer to Oracle AI Database@Azure — Azure Log Analytics.
Exploring GoldenGate events using KQL
Once diagnostic settings are configured and events are being collected, administrators can explore the available records in their Log Analytics workspace. For example, suppose an administrator wants to investigate operational events associated with a GoldenGate deployment during the last 24 hours.
They can open Log Analytics workspace → Logs, identify the table containing the GoldenGate diagnostic records, and use KQL to filter those records by deployment and time range.Azure Monitor stores resource logs using either the AzureDiagnostics table or resource-specific tables, depending on the resource and collection mode. Consequently, administrators should identify the actual destination table before writing GoldenGate-specific queries.
The following is a simple exploratory query to identify tables containing recently collected records associated with a GoldenGate deployment:
OracleCloudDatabase
| where TimeGenerated > ago(30d)
| where tostring(_ResourceId) contains "<GOLDENGATE_AZURE_RESOURCE_ID>"
| project TimeGenerated, OperationName, LifeCycleState, Type
| order by TimeGenerated desc
| take 100
Replace <GOLDENGATE_AZURE_RESOURCE_ID> with the Azure resource ID of your GoldenGate deployment.
This query provides a starting point for identifying relevant diagnostic records. The actual resource-identification field and available tables should be verified against the collected data.
Once the appropriate table has been identified, administrators can create more focused queries to investigate critical events, deployment updates, or operational activity within a particular time window. For example, these queries can help answer questions such as:
  • Were there any critical operational events during the replication incident?
  • Were deployment configuration changes made around the time replication performance degraded?
  • What GoldenGate-related resource events occurred during the previous 24 hours?
Customers can also convert query results into visualizations or create Azure Monitor log-search alerts based on supported diagnostic records.
(Optional) Exploring AI-Powered Observability with Azure Copilot Observability Agent
As enterprise environments grow more complex, monitoring tools are increasingly incorporating AI capabilities to help operations teams investigate issues more efficiently. Microsoft’s Azure Copilot Observability Agent introduces AI-assisted observability capabilities that help users explore supported telemetry, investigate operational issues, and identify potential relationships between monitoring signals.
For example, consider the replication-lag scenario discussed earlier. Instead of manually analyzing individual charts and event records, an administrator could use an AI-assisted investigation experience, where supported, to ask:
“Analyze the monitoring data from the last 30 minutes. Identify any unusual CPU or memory utilization trends, relevant operational events, and possible factors contributing to the reported replication delay.”
The goal is to simplify the investigation process by helping administrators correlate available telemetry and identify areas that require further analysis. For GoldenGate customers, AI-assisted observability represents a promising direction for reducing investigation effort and making operational information more accessible through natural-language interactions.
As Azure’s AI observability capabilities evolve, they could further complement the monitoring and diagnostic information already available through GoldenGate and Azure Monitor.
Best Practices for Monitoring Oracle GoldenGate on Azure
To get the most value from the Azure-native monitoring experience, consider the following recommendations:
  • Monitor replication and infrastructure together: Track Extract Lag, Replicat Lag, and Heartbeat Lag alongside CPU, memory, and storage utilization for a broader view of replication performance.
  • Configure proactive alerts: Establish meaningful thresholds based on application requirements and replication latency objectives.
  • Centralize operational events: Enable supported diagnostic settings to collect GoldenGate-related events in Azure Log Analytics.
  • Use dashboards for consolidated visibility: Bring important GoldenGate metrics into shared Azure dashboards alongside other relevant infrastructure monitoring information.
  • Validate monitoring configurations: Test alert delivery and verify that expected diagnostic events are available before relying on these integrations for production operations.
These practices help organizations establish consistent monitoring and troubleshooting workflows across GoldenGate and their broader Azure environments.
Conclusion
With Azure Monitor and Azure Log Analytics integration, Oracle GoldenGate on Oracle AI Database@Azure extends its Azure-native experience beyond provisioning and management to monitoring and observability.
Customers can monitor replication health and performance, configure proactive alerts, and investigate supported operational events—all through familiar Azure monitoring capabilities.
For organizations already using Azure Monitor, this provides a more consistent way to incorporate GoldenGate into existing operational dashboards, monitoring processes, and incident-management workflows. And as AI-assisted observability continues to evolve, capabilities such as Azure Copilot Observability Agent offer further opportunities to simplify operational investigations.
The result is greater visibility into business-critical replication workloads and a more integrated monitoring experience for Oracle GoldenGate customers operating in Azure.
Additional Resources
