Cryptography is a major component of secure e-commerce.
Since cryptography is compute intensive and adds a significant load to applications, such as SSL web servers (https), crypto performance is an important factor.
Providing accelerated crypto hardware greatly helps these applications and will help lead to a wider adoption of cryptography, and lower cost, in e-commerce and other applications.
The Intel Westmere microprocessor has six new instructions to acclerate AES encryption.
They are called "AESNI" for "AES New Instructions".
These are unprivileged instructions, so no "root", other elevated access, or context switch is required to execute these instructions.
These instructions are used in a new built-in OpenSSL 1.0 engine available in Solaris 11, the aesni engine.
Previously,
AESNI instructions were introduced into the Solaris kernel and libraries for the Intel Westmere platform.
That is, the "aes" kernel module (used by IPsec and other kernel modules) and the Solaris pkcs11 library (for user applications). These are available in Solaris 10 10/09 (update 8) and above, and Solaris 11.
The work here is to add the aesni engine to OpenSSL.
As mentioned above, six new instructions acclerate AES encryption in processor silicon. The new instructions are:
Since the AESNI instructions are implemented in hardware, they take a constant number of cycles and are not vulnerable to side-channel timing attacks that attempt to discern some bits of data from the time taken to encrypt or decrypt the data.
Having X86 AESNI hardware crypto instructions is all well and good, but how do we access it?
The software is available with Solaris 11 and is used automatically
if you are running Solaris on a AESNI-capable processor (such as Intel Westmere-class processors).
AESNI is used internally in the kernel through kernel crypto modules and
is available in user space through the PKCS#11 library.
For OpenSSL on Solaris 11, AESNI crypto is available directly with a new built-in OpenSSL 1.0 engine, called the "aesni engine."
This is in lieu of the extra overhead of going through the Solaris OpenSSL pkcs11 engine,
which accesses Solaris crypto and digest operations.
Instead, AESNI assembly is included directly in the new aesni engine.
Instead of including the aesni engine in a separate library in /lib/openssl/engines/,
the aesni engine is "built-in", meaning it is included directly in OpenSSL's libcrypto.so.1.0.0 library.
This reduces overhead and the need to manually specify the aesni engine.
Since the engine is built-in (that is, in libcrypto.so.1.0.0), the openssl -engine command line flag or API call is not needed to access the engine—the aesni engine is used automatically on AESNI hardware.
The Openssl aesni engine auto-detects if it's running on AESNI hardware and uses AESNI encryption instructions
for these ciphers:
AES-128-CBC, AES-192-CBC, AES-256-CBC,
AES-128-CFB128, AES-192-CFB128, AES-256-CFB128,
AES-128-CTR, AES-192-CTR, AES-256-CTR,
AES-128-ECB, AES-192-ECB, AES-256-ECB,
AES-128-OFB, AES-192-OFB, and AES-256-OFB.
The AESNI assembly language routines are not a part of the regular Openssl 1.0.0 release.
AESNI is a part of the "HEAD" ("development" or "unstable") branch of OpenSSL, for future release.
But AESNI is also available as a
separate patch provided by Intel to the OpenSSL project for OpenSSL 1.0.0.
A minimal amount of "glue" code in the aesni engine works between the OpenSSL libcrypto.so.1.0.0 library and the assembly functions.
The aesni engine code is separate from the base OpenSSL code and requires patching only a few source files to use it. That means OpenSSL can be more easily updated to future versions without losing the performance from the built-in aesni engine.
Here's some graphs of aesni engine performance I measured by running
openssl speed -evp $algorithm where $algorithm is aes-128-cbc, aes-192-cbc, and aes-256-cbc.
These are using the 64-bit version of openssl on the same AESNI hardware, a Sun Fire X4170 M2 with a Intel Xeon E5620 @2.40GHz, running Solaris 11 FCS.
"Before" is openssl without the aesni engine and "after" is openssl with the aesni engine.
The numbers are MBytes/second.
alt="Chart showing AESNI Openssl engine performance for AES CBC mode on Sun Fire X4170 with Solaris 11" />
OpenSSL aesni engine performance on Sun Fire X4170 M2 (Xeon E5620 @2.40GHz)
(Higher is better; "before"=OpenSSL on AESNI without AESNI engine software, "after"=OpenSSL AESNI engine)
As you can see the speedup is dramatic for all 3 key lengths and for data sizes from 16 bytes to 8 Kbytes—AESNI is about 7.5-8x faster over hand-coded amd64 assembly (without aesni instructions).
The easiest way to determine if you are running the aesni engine is to type "openssl engine"
on the command line.
No configuration, API, or command line options are needed to use the OpenSSL aesni engine.
If you are running on Intel AESNI hardware with Solaris 11 FCS, you'll see this output indicating you are using the aesni engine:
intel-westmere $$ openssl engine |
If you are running on Intel without AESNI hardware you'll see this output indicating the hardware can't support the aesni engine:
intel-nehalem $ openssl engine |
For Solaris on SPARC or older Solaris OpenSSL software, you won't see any aesni engine line at all.
Third-party OpenSSL software (built yourself or from outside Oracle) will not have the aesni engine either.
Solaris 11 FCS comes with OpenSSL version 1.0.0e. The output of typing
"openssl version"
should be "OpenSSL 1.0.0e 6 Sep 2011".
OpenSSL comes in both 32- and 64-bit binaries.
64-bit executable is now the default, at /usr/bin/openssl, and OpenSSL 64-bit libraries at
/lib/amd64/libcrypto.so.1.0.0 and libssl.so.1.0.0
The 32-bit executable is at /usr/bin/i86/openssl and
the libraries are at
/lib/libcrytpo.so.1.0.0 and libssl.so.1.0.0.
The OpenSSL AESNI engine is available in Solaris 11 for both the 64- and 32-bit versions of OpenSSL.
It is not available with Solaris 10.
You must have a processor that supports AESNI instructions (such as Intel Westmere), otherwise OpenSSL will fallback to the older, slower AES implementation without AESNI.
Processors that support AESNI include most Westmere and Sandy Bridge class processor architectures. Some low-end processors (such as for some mobile/laptop platforms) do not support AESNI. The easiest way to determine if the processor supports AESNI is with the isainfo -v command—look for "amd64" and "aes" in the output:
$ isainfo -v |
The Solaris 11 OpenSSL aesni engine provides easy access to powerful Intel AESNI hardware cryptography,
in addition to Solaris userland PKCS#11 libraries and Solaris crypto kernel modules.
With the Solaris 11.2 update, the OpenSSL aesni engine has been removed. That's because the upstream OpenSSL community has integrated X86 AES-NI instructions directly in the mainline OpenSSl crypto code, so a separate aesni engine is no longer needed or used. OpenSSL automatically detects if it's running on an X86 processor with AES-NI crypto instructions.
For more information see the Misaki Miyashita's blog, "OpenSSL on Oracle Solaris 11.2".
