X
Proactive insights, news and tips from Oracle Hyperion EPM and BI Support. Learn Oracle from Oracle.
Using Application Monitor to Manage Your Enterprise Performance Management (EPM) Cloud Applications
Tanya Heise
Sr Principal Technical Support Engineer
About the Application Monitor
The Application Monitor enables administrators, at design-time, to identify and resolve design flaws before an application is placed in production (and on an ongoing basis, as the application evolves with new members and data is added to the application) and used by end users.
Administrators can use the application monitor to evaluate the following:
  • An entire application
  • Types of artifacts such as forms and approval units
  • Individual "cherry picked" artifacts
The application monitor identifies changes that administrators can make at design-time to resolve artifacts with design flaws, and provides easy access to the editors required to modify them. At runtime, internal processes perform checks that may deny system request if artifacts need to be modified. The application monitor evaluates your application and artifacts based on the user an administrator selects. This enables you to determine the potential problems that may occur at runtime given the individual user's variables and security access as part of the analysis.
How the Application Monitor Works
The application monitor evaluates applications as follows:
  • At design-time—Analyzes the application or specific artifacts in terms of all possible problems that could occur. To determine this worst possible situation, suppression options (such as those used with forms) are ignored. The application monitor provides information about how to fix the design flaws it encounters.
  • At runtime—Internal governors perform checks that may prevent users from performing particular actions if the design flaws found are not resolved.
Use the application monitor to analyze the following:
  •     Block storage cubes
  •     Dimensions
  •     Simple forms
  •     Standalone business rules
  •     Approval unit hierarchies
  •     Reporting mappings
  •     Export data functionality
How to launch the monitor and use the graphs:
References:
Be the first to comment
Comments ( 0 )
Please enter your name.Please provide a valid email address.Please enter a comment.CAPTCHA challenge response provided was incorrect. Please try again.
