X
Proactive insights, news and tips from Oracle Hyperion EPM and BI Support. Learn Oracle from Oracle.
  • April 8, 2013
FDM & ERPI to be combined into FDMEE starting with 11.1.2.3.x
Guest Author
(in via Lia)
Starting with release 11.1.2.3,
Oracle Financial Data Quality Management (FDM)
and
Oracle Hyperion Financial Data Quality Management ERP Integration Adapter for Oracle Applications (ERPI)
are being combined into a single product named
Oracle Financial Data Quality Management, Enterprise Edition (FDMEE)
built on the Oracle Fusion Middleware platform.
Pricing and related adapters remain unchanged, and there is no fee for existing FDM customers to migrate to FDMEE.
Existing customers may:
  • upgrade to FDM version 11.1.2.3,
  • migrate to FDMEE 11.1.2.3,
  • or run both in parallel.
New customers may license FDMEE 11.1.2.3 only.
Please note that starting with EPM 11.1.2.4, existing FDM customers will be required to migrate to FDMEE if they chose to upgrade other EPM products to release 11.1.2.4. (Release 11.1.2.3 is the last release of FDM as it is currently offered.)
Please note that enhancements will not be provided for the current FDM and ERPI products after the 11.1.2.3 release.
Customers who wish to take advantage of enhanced features and functionality should plan to migrate to FDMEE.
Support for these products follows the published  Oracle Lifetime Support Policy Guidelines.
Any questions related to this announcement should be directed to your Oracle account manager.
This information was also announced in the Oracle Knowledgebase
under  KM Doc ID 1542470.1
Join the discussion
Comments ( 4 )
  • guest Wednesday, June 25, 2014
    I am using FDMEE 11.1.2.3, the Oracle docs stated that the target application adapter is already included within the installation, is this right? I am asking because I cant see the adapter in the workbench.
    Additionally, If it is not included what is the adapter that I should install, and from where I can get it.
    Thanks in advance,
    Moha.
  • guest Friday, June 27, 2014
    Hi Moha
    If you are using FDMEE then there are no target adapters that need to be imported (as there were with FDM). They are already built into the product.
    In FDMEE the Workbench is actually the 'Data Load Workbench' which is where you can run and view the data workflow, again unlike FDM where the workbench was a separate client used for configuration etc.
    I hope this helps
    Sarah
  • guest Wednesday, August 20, 2014
    Does it mean that we don't need to buy separate lincense for FDM adapter suite (for Oracle EBS integration) when we buy FDMEE?
    Can you please confirm?
    Regards,
    Praveen
  • Lia Thursday, August 21, 2014
    Hi Praveen,
    Please talk to your account manager about licensing, this is something we can't discuss on the blog.
    Regards
    Lia
Please enter your name.Please provide a valid email address.Please enter a comment.CAPTCHA challenge response provided was incorrect. Please try again.
