Download a PDF of this article
From time to time, you may need to break the rules. In the Java platform, this is normally accomplished by using one of three primary mechanisms: reflection, class loading (including associated bytecode transformation), and Unsafe.
Java power users should understand all three of these techniques, even if they resort to them only when necessary. The principle “just because you can do something, does not mean that you should” applies to design choices in software as much as it does elsewhere.
Of the three, Unsafe is the most potentially dangerous (and therefore powerful) because it provides a way to do certain things that are otherwise impossible and that break well-established rules of the platform.
For example, Unsafe allows developers to
The Java 8 Unsafe class, sun.misc.Unsafe, warns us of its very nature immediately, not only in its name, but also by the package in which it lives. The sun.misc package is an internal, implementation-specific location, and Java code should never touch it directly. In Java 9 and later versions, this backstage nature is made even clearer because the functionality of Unsafe moved to a module called jdk.unsupported.
Java libraries are, of course, not supposed to couple directly to these types of implementation details. To reinforce this standpoint, the attitude of Java’s platform maintainers has long been that to do so is dangerous and that application developers who break the rules by linking to internal details do so at their own risk.
Despite these obvious red flags, the inconvenient truth of Unsafe is that it has become ubiquitous. Virtually every major framework in the Java ecosystem relies on one or more capabilities provided by Unsafe. It is not an exaggeration to say that the dynamism, flexibility, and performance that modern Java developers have come to expect is largely derived from usage of Unsafe in one form or another.
Let’s examine a classic use of Unsafe for the use of the hardware feature known as “compare and swap” or CAS. This capability is present on virtually all modern CPUs, but famously is not a part of Java’s memory model.
In my first example, I’ll stick to the rules and use synchronization, which forms a part of Java’s memory model:
public final class SynchronizedCounter implements Counter {
private int i = 0;
@Override
public synchronized int increment() {
return i = i + 1;
@Override
public synchronized int get() {
return i;
}Now, let’s compare that to the AtomicCounter Unsafe implementation, which contains significantly more boilerplate, due to having to access the Unsafe class reflectively:
public final class AtomicCounter implements Counter {
private static final Unsafe unsafe;
private static final long valueOffset;
private volatile int value = 0;
static {
try {
Field f = Unsafe.class.getDeclaredField("theUnsafe");
f.setAccessible(true);
unsafe = (Unsafe) f.get(null);
valueOffset = unsafe.objectFieldOffset
(AtomicCounter.class.getDeclaredField("value"));
} catch (Exception ex) { throw new Error(ex); }
@Override
public int increment() {
return unsafe.getAndAddInt(this, valueOffset, 1) + 1;
@Override
public int get() {
return value;
}The performance difference between these two is considerable: The Unsafe implementation runs roughly two-to-three times faster on modern hardware.
Important reminder: As I already discussed, virtually all modern frameworks already use Unsafe behind the scenes. As an application developer, you should not assume that your code will see any performance benefit whatsoever if you code against Unsafe directly. The framework developers have already taken advantage of Unsafe whenever it makes sense and do so in a safe manner. Therefore, you should use whatever your framework of choice provides.
If you trace down into the code of AtomicCounter and its supporting code in the JDK, you can see that this implementation is doing several things that are supposedly impossible in Java.
First of all, it computes a pointer offset (the offset where the field value lives relative to the start of AtomicCounter objects). There is no sequence of JVM bytecode instructions that can provide this; only native code that directly accesses the JVM’s internal data structures can do it.
Next, it directly accesses memory via pointer offset, not by field indirection. Finally, it chooses the memory access mode (in this case, volatile) in which to do so—instead of having that be determined by how the variable is declared.
This isn’t quite “six impossible things before breakfast,” but it’s pretty close!
Strictly speaking, the code breaks the rules of the Java specification by doing all this, because it is using internal capabilities that do not necessarily follow the rules in the way that user code is supposed to.
However, in practice, everyone knows that no Java developer is really willing to significantly degrade performance simply to maintain strict adherence to the Java spec. The real problem is that the Unsafe capability is altogether too easy to access and developers should not be encouraged to use it.
This, therefore, leads to a fundamental question: How can Java get rid of the Unsafe class while keeping the gains in performance and functionality that Unsafe has enabled and upon which the modern Java ecosystem now relies?
Given the extent to which Unsafe is used (directly or indirectly) in modern Java applications, these are the only choices:
Unsafe and risk breaking unknowable numbers of Java applicationsIn practice, this is no choice at all. Removing access without due notice and consideration would risk a de facto fork in the platform (such as that between Python 2 and Python 3, or worse).
If access to Unsafe were simply shut off, it would prevent almost all Java applications from upgrading, because essentially any nontrivial application uses a library that has a transitive dependency on functionality in Unsafe.
Related to this (and often underappreciated) is the need for the Java platform development team to be able to change internal implementation details freely, without worrying that end user Java applications (or the libraries that support them) are depending on those details.
This situation shows another essential problem at the heart of Unsafe. On the one hand, in recent versions, Java has evolved from a platform that has leaky encapsulation to something that aspires to much better modularity boundaries. On the other hand, Unsafe has become a stumbling block in the adoption of a modules system.
Solving this requires compromise. By Java 11, many of these methods have been migrated into two separate classes: jdk.internal.misc.Unsafe (in java.base) and sun.misc.Unsafe (in jdk.unsupported).
The jdk.unsupported module is declared like this:
module jdk.unsupported {
exports sun.misc;
exports sun.reflect;
exports com.sun.nio.file;
opens sun.misc;
opens sun.reflect;
}This declaration provides access for any application that explicitly depends upon the unsupported module and, crucially, it also provides unrestricted reflective access to sun.misc, the package containing Unsafe.
Although this helps move Unsafe into a more module-friendly form, you might legitimately ask, “For how long should this compromise solution be maintained?”
To really get rid of Unsafe, the reflective access encapsulation hole needs to be closed, and this is probably best addressed by a change in the general reflection policy. When Java 9 was under development, the widespread usage of unrestricted reflection meant that a compromise position of defaulting to --illegal-access=permit was chosen.
This was intended to be only temporary, however. So, let’s revisit the necessity of both of these temporary compromises.
Some methods have actually been removed from Unsafe, including
fieldOffset()monitorEnter()monitorExit()tryMonitorEnter()The defineClass() method was also moved to the MethodHandles class as part of Java 9.
Another major step forward is the introduction of the VarHandle API, which was added in Java 9 largely to provide safe replacements for some of the APIs in Unsafe.
One important goal of VarHandle is to include replacements for CAS functionality and access to volatile fields and arrays. To see this in action, let’s look at a quick example that shows how you might approach using VarHandle to replace Unsafe in an atomic counter:
public class AtomicVHCounter implements Counter {
private static final VarHandle vh;
static {
try {
MethodHandles.Lookup l = MethodHandles.lookup();
vh = l.findVarHandle(AtomicVHCounter.class, "value",
int.class);
} catch (ReflectiveOperationException e) {
throw new Error(e);
@Override
int i;
do {
i = (int) vh.getVolatile(this);
} while (!vh.compareAndSet(this, i, i + 1));
return i;
@Override
public int get() {
return value;
}This code is functionally equivalent to the previous version that uses Unsafe, but this code now uses only fully supported APIs. The key steps are
Lookup object to obtain a VarHandle for the appropriate fieldVarHandleVarHandle to access the field, using volatile memory semanticsThe use of MethodHandles.Lookup is a very important change. Unlike reflection, which relies upon setAccessible()to access private fields, the Lookup object has whatever permissions the calling context does, which includes access to the private field value.
The migration away from reflection and towards method and field handles means that a number of methods that were present in Unsafe in Java 8 have been removed from the unsupported API, including
compareAndSwapInt()compareAndSwapLong()compareAndSwapObject()The equivalents of these methods are now found on VarHandle, along with a number of useful accessor methods. There are also get and put methods for the primitive types and Object, in both normal and volatile access modes, as well as methods for building efficient adders, such as
getAndAddInt()getAndAddLong()getAndSetInt()getAndSetLong()getAndSetObject()Another key goal of VarHandle is to allow low-level access to the new memory order modes available in JDK 9 and later.
Overall, definite progress has been made in creating alternatives to the de facto APIs of Unsafe. For example, as well as VarHandle, the getCallerClass() functionality from Unsafe is now available in the Stack-Walking API (JEP 259). However, there is still more to do.
One other major area of progress is the work towards implementing hidden classes, as described in JEP 371. This JEP relates to one of the most common usages of Unsafe: the desire to create on-the-fly classes that cannot be used directly by other classes (but can be handled reflectively).
These classes have sometimes been referred to as anonymous classes, and the method in Unsafe is called defineAnonymousClass(). However, that term can be confusing to developers, because in the context of normal Java application code, it means a nested implementation of some interface that declares its static type to be the interface, like this:
public class Scratch {
public void foo() {
Runnable r = new Runnable() {
@Override
public void run() {
System.out.println("We had to do it this way before lambdas!");
}Many Java programmers know that classes like this implementation of Runnable are not really anonymous, because the compiler will generate a class named something like Scratch$1, which is a genuine and usable Java class. Although the class name is not available to Java source code, the class can be found using that name and accessed reflectively and then used just like any other class.
However, in this context of talking about Unsafe, I mean something different. That’s why the term hidden classes should be used instead.
A hidden class is not truly anonymous either, because it has a name that is available by directly invoking getName() on its Class object. This name can also show up in sevaral other places, including diagnostic, JVM tool interface, or Java Flight Recorder events. However, hidden classes cannot be found using a class loader or in any way that regular classes can be found, such as by using reflection (for example, via Class.forName()).
The intention is that hidden classes are named in a way that explicitly puts them in a different namespace than regular classes.
In the current version of the implementation of hidden classes (which is still being developed in the OpenJDK project), the naming scheme exploits the fact that in the JVM, class names typically have two forms. There’s the binary name (com.acme.Gadget), which is returned by calling getName() on a Class object. And there’s the internal form (com/acme/Gadget).
Hidden classes aren’t named using that same pattern. Instead, a name such as com.acme.Gadget/1234 would be returned by calling getName() on the Class object of a hidden class. This is neither a binary name nor an internal form, and any attempt to make a regular class that matches this name will fail.
One advantage of this naming scheme (and differentiating hidden classes in this way) is that they need not be subject to the usual vigorous scrutiny of the JVM’s class loading mechanism. This fits with the overall design that hidden classes are intended for use by framework authors and others who need capabilities that go beyond the usual bulletproof checks imposed on general Java classes.
In the context of Unsafe, JEP 371 aims to deprecate the defineAnonymousClass() method from Unsafe, with the overall goal being able to remove it in a future release, once hidden classes are supported as part of the Lookup API.
This is a purely internal change. There is no suggestion that the arrival of hidden classes will change the Java programming language in any way, at least initially. However, the implementations of classes such as LambdaMetaFactory, StringConcatFactory, and LambdaForms will be updated to use the new APIs.
Let’s consider which use cases need to be supported. Some important special cases are those of mocks and proxies. For those purposes, you can consider these to be objects with two special properties, specifically that they
Many modern libraries and frameworks make use of the capabilities of the low-level Objenesis project to achieve this. Objenesis uses different mechanisms (none that are publicly available) to achieve this, and one of them is allocateInstance() from Unsafe.
Therefore, to fully get rid of Unsafe, either this method or an equivalent capability needs to be migrated to a supported API. Java developers will still need an official way to create mocks and proxies.
This boils down to the need for an official way to instantiate an object without calling any of its class’s constructors. To put it another way, space needs to be allocated for it and its instance metadata needs to be set up so the resulting object can be substituted for an instance of the original class.
For mock objects, this could be solved by creating a new jdk.test module that provides a special API for libraries to use when creating mocks. However, this does not solve the issue for proxies, which are used by application code at runtime, not just during testing.
This issue has also been conflated with serialization, as the current mechanism for deserialization bypasses the declared constructors of the class. A clever framework developer is thus able to piggyback mock or proxy instantiation on top of a serialization API. Creating an object that way has always been possible since the earliest days of Java.
However, this approach is not sustainable for the long term. There are clear indications that at some point in the future, the serialization spec will be modified and will use constructors for deserialization, closing off a key mechanism that proxying libraries rely upon.
Major progress has been made in removing the dangerous parts of Unsafe and replacing them with standardized, supported APIs that framework and library authors can depend upon. However, although the end is in sight, the work is not done, because some functionality still relies on these unsafe methods for which there is no comparable replacement.
With luck, over the next few releases of Java, this process will be completed, and the reliance of so much of the Java ecosystem on nonstandard capabilities will end.
Ben Evans (@kittylyst) is a Java Champion and Senior Principal Software Engineer at Red Hat. He has written five books on programming, including Optimizing Java (O'Reilly) and The Well-Grounded Java Developer (Manning). Previously he was Lead Architect for Instrumentation at New Relic, a founder of jClarity (acquired by Microsoft) and a member of the Java SE/EE Executive Committee.
