X
Proactive insights, news and tips from Oracle Fusion Middleware Support. Learn Oracle from Oracle.
Top Documents Linked to SRs as Solutions for JDeveloper/ADF Issues 01/2016 thru 5/2016
Guest Author
Top documents linked to SRs as solutions for JDeveloper/ADF issues 01/2016 thru 05/2016.
1465411.1 Where to Find Oracle Java Development Products Documentation The purpose of this document is to assist you to locate the Oracle Java Development product documentation
1599898.1 Supportability on Internet Explorer 11 (IE11) with Oracle ADF Currently, Oracle ADF is NOT CERTIFIED with Microsoft Internet Explorer 11. Oracle JDeveloper Releases: Provides a release matrix for Oracle JDeveloper.  We recommend you to regularly check the certification matrix.
971256.1 How to Request the ADF Libraries Source This
document describes the process for requesting access to the ADF
Libraries Source Code. It is a guide for the customers to show the
process behind it
2010222.1 How to use ADF Desktop Integration Client Health Check Tool   To check if the desktop configuration and environment are good for ADFdi and resolve problems
1985368.1 Incorrect Download File Name In IE11 - af:exportCollectionActionListener and af:fileDownloadActionListener  When using IE11, the name of the file being download is not correct. The problem reproduces in both af:exportCollectionActionListenerand af:fileDownloadActionListener components, but only when the application is deployed in the JDeveloper's embedded WebLogic server.
1942687.1 ADF Application Fault With ADFC-12000  In FMW 11.1.1.7, An ADF application causes an intermitent error which can occur in any place of the BPM customized ADF TaskFlow:oracle.adf.controller.internal.AdfcIllegalStateException: oracle.adf.controller.ControllerException: ADFC-12000
1344952.2 Information Center: Oracle JDeveloper & ADF 11g and 12c .
1967035.1 Apply a Patch with Both Design Time (DT) and Run Time (RT) parts  How to recognize and apply a patch for JDeveloper/ADF 11g that has both a design time (DT) and run time (RT) parts?
401694.1 Oracle JDeveloper release matrix.
2035781.1 SRDC - JDeveloper IDE/Other Issues Data Collection   The process outlined will guide the user through collecting diagnostic data, which will help Support narrow down the cause of your problem.
Be the first to comment
Comments ( 0 )
Please enter your name.Please provide a valid email address.Please enter a comment.CAPTCHA challenge response provided was incorrect. Please try again.
