X
Proactive insights, news and tips from Oracle Fusion Middleware Support. Learn Oracle from Oracle.
Top 10 solution documents for OWSM and OAG/OEG
Guest Author
The following are the top 10 documents that are linked to SRs as
solutions, for Oracle Web Services Manager (OWSM) and Oracle API Gateway (OAG/OEG) , from 1 Jan 2014 thru 1 May 2014
1481062.1 Enterprise Manager Cannot Invoke WS Policy Manager When Managed Servers SSL Port Is Enabled  According to the documentation http://docs.oracle.com/cd/E23943_01/web.1111/b32511/diagnosing.htm#BABHEHHI. which mentioned that by default the OWSM auto look up feature tries to connect over SSL.
1604041.1 Error Message " "Too many open files" in Gateway logs or warning:  cannot create interrupt pipe for thread:  Too many open files
1569900.1 Misconfigured
Policy Accessor URL in config/fmwconfig/policy-accessor-config.xml or
Any Inconsistent SSL configuration in the Weblogic Domain can break
OWSM.
1618855.1 Error
"WSM-00035 : Error in Signature reference mechanism compliance :
Expected : thumbprint , Actual : direct" When Using SAML With OWSM.
A SAML based OWSM service policy is used, such as oracle/wss11_saml_or_username_token_with_message_protection_service_policy Requests sent to the service fail even though the correct client policy is attached on the client side.
1419373.1 SBL-EAI-08000 Error While Calling Siebel UCM (Universal Customer Master) Organization Service From SOA 11g  Unable to process SOAP Header child element 'wsse:Security' with 'mustUnderstand="1"'(SBL-EAI-08000).
726219.1 For
debugging purposes when you have a problem or during development, you
may want to increase this log level to get further details.
1485851.1 After an upgrade from FMW 11.1.1.3 or earlier to FMW 11.1.1.4 or later, Web Services secured with OWSM fail.
1311343.1 Importing an OWSM 11g Custom Policy File in EM Fails with WSM-02079 "Insufficient Permission To Access EJB" Error  When trying to import a custom Oracle Web Services Manager (OWSM) policy
file using Enterprise Manager (EM) in Oracle Fusion Middleware 11g
following these steps in the docs, it fails .
1585107.1 How To Configure SMTP And Send Reports Through Email On OEG?
1358581.1 How to Change the Database Instance Being Used By OWSM 10g  The database ORAWSM schema has been moved from one database instance to
another. How can the OWSM instance be changed to use the new database
instance?
Be the first to comment
Comments ( 0 )
Please enter your name.Please provide a valid email address.Please enter a comment.CAPTCHA challenge response provided was incorrect. Please try again.
