- Export the data from the database on the old platform, create a new database on the new platform, and import the data into the new database.
- Use the Transportable Database feature
SQL> select platform_name from v$db_transportable_platform;
If the intended target platform appears in the output, Transportable Database can then be used to migrate the database to this target. Otherwise, an alternative such as export/import should be used instead. Not the same as Cross-Platform Transportable Tablespaces (XTTS) Please note that an alternative database technology known as Cross-Platform Transportable Tablespaces (XTTS) to migrate data between platforms of different endian formats is NOT yet certified with Oracle E-Business Suite. References
- Using Transportable Database to migrate Oracle E-Business Suite Release 11i Using Oracle Database 10g Release 2 or 11g Release 1 (Note 729309.1)
- Using Transportable Database to migrate Oracle E-Business Suite Release 12 Using Oracle Database 10g Release 2 or 11g Release 1 (Note 734763.1)
- Platform Migration using Transportable Database Oracle Database 11g and 10g Release 2 (OTN, PDF 284K)
- Migrating E-Business Suite Release 12 Databases Between Platforms
- Migrating E-Business Suite Release 11i Databases Between Platforms
- Call for Early Adopter Program Participants: Using Cross-Platform Transportable Tablespaces with Apps 11i
- Database 11gR1 Version 11.1.0.7 Certified with EBS 12
- Database 11gR1 Version 11.1.0.7 Certified with EBS 11i
