Oracle Advanced Security is an optional licenced Oracle 11g Database add-on. Oracle Advanced Security Transparent Data Encryption (TDE) offers two different features: column encryption and tablespace encryption. TDE Tablespace Encryption 11.2.0.2 is now certified with Oracle E-Business Suite Release 11i (11.5.10.2 + ATG PF.H RUP 6 and higher) and Release 12 (Releases 12.0.6 and higher and 12.1.1 and higher).
What is Transparent Data Encryption (TDE) ?
TDE is completely transparent to existing applications with no triggers, views or other application changes required. Data is transparently encrypted when written to disk and transparently decrypted after an application user has successfully authenticated and passed all authorization checks. Authorization checks include verifying the user has the necessary select and update privileges on the application table and checking Database Vault, Label Security and Virtual Private Database enforcement policies.
Existing database backup routines will continue to work, with the data at rest remaining encrypted in the backup. For encryption of entire database backups, TDE can be used in combination with Oracle RMAN.
What is Tablespace Encryption ?
New in Oracle Database 11g, the Oracle Advanced Security now includes support for tablespace encryption.
When a tablespace is created through Enterprise Manager or on the command line, an option now exists to specify that the file be encrypted on the file system. When new data is added to the new tablespace using the insert command or datapump, entire tables will be transparently encrypted. When the database reads data blocks from the encrypted tablespace it will transparently decrypt the data blocks.
With this certification, Oracle E-Business Suite environments can be migrated to the latest 11gR2 version of encrypted tablespaces. For more information, see:
- Using TDE Tablespace Encryption with Oracle E-Business Suite Release 11i (Note 828223.1)
- Using TDE Tablespace Encryption with Oracle E-Business Suite Release 12 (Note 828229.1)
This database option is certified for all EBS platforms on which Oracle Database 11.2.0.2 is certified. You can refer to the Certifications system on My Oracle Support for details about certified EBS platforms for this database release.
Related Articles
- 11gR2 11.2.0.2 Database Certified with E-Business Suite
- TDE Tablespace Encryption 11.2.0.1 Certified with EBS 12
- TDE Tablespace Encryption 11.2.0.1 Certified with EBS 11i
