Java log
The latest Java Runtime Environment 1.6.0_111 (a.k.a. JRE 6u111-b12) and later updates on the JRE 6 codeline are now certified with Oracle E-Business Suite Release 12.x for Windows-based desktop clients.
All JRE 6, 7, and 8 releases are certified with EBS upon release
Our standard policy is that all E-Business Suite customers can apply all JRE updates to end-user desktops:
  • From JRE 1.6.0_03 and later updates on the JRE 6 codeline
  • From JRE 1.7.0_10 and later updates on the JRE 7 codeline
  • From JRE 1.8.0_25 and later updates on the JRE 8 codeline
We test all new JRE releases in parallel with the JRE development process, so all new JRE releases are considered certified with the E-Business Suite on the same day that they’re released by our Java team.
You do not need to wait for a certification announcement before applying new JRE 6, 7, or 8 releases to your EBS users’ desktops.
Effects of new support dates on Java upgrades for EBS environments
Support dates for the E-Business Suite and Java have changed.  Please review the sections below for more details:
  • What does this mean for Oracle E-Business Suite users?
  • Will EBS users be forced to upgrade to JRE 7 for Windows desktop clients?
  • Will EBS users be forced to upgrade to JDK 7 for EBS application tier servers?
New EBS installation scripts
This JRE release is the first with a 3-digit Java version. Installing this in your EBS 11i and 12.x environments will require new installation scripts.  See the documentation listed in the ‘References’ section for more detail.
32-bit and 64-bit versions certified
This certification includes both the 32-bit and 64-bit JRE versions for various Windows operating systems. See the respective Deploying JRE documentation for your EBS release for details.
Implications of Java 6 End of Public Updates for EBS Users
The Support Roadmap for Oracle Java is published here:
The latest updates to that page (as of Sept. 19, 2012) state:
Java SE 6 End of Public Updates Notice
After February 2013, Oracle will no longer post updates of Java SE 6 to its public download sites. Existing Java SE 6 downloads already posted as of February 2013 will remain accessible in the Java Archive on Oracle Technology Network. Developers and end-users are encouraged to update to more recent Java SE versions that remain available for public download. For enterprise customers, who need continued access to critical bug fixes and security fixes as well as general maintenance for Java SE 6 or older versions, long term support is available through Oracle Java SE Support .
EBS users fall under the category of “enterprise users” above.  Java is an integral part of the Oracle E-Business Suite technology stack, so EBS users will continue to receive Java SE 6 updates from February 2013 to the end of Java SE 6 Extended Support in June 2017.
In other words, nothing changes for EBS users after February 2013.
EBS users will continue to receive critical bug fixes and security fixes as well as general maintenance for Java SE 6 until the end of Java SE 6 Extended Support in June 2017.
How can EBS customers obtain Java 6 updates after the public end-of-life?
Java 6 is now available only via My Oracle Support for E-Business Suite users.  You can find links to this release, including Release Notes, documentation, and the actual Java downloads here:   Both JDK and JRE packages are contained in a single combined download after 6u45.  Download the “JDK” package for both the desktop client JRE and the server-side JDK package.
Coexistence of multiple JRE releases Windows desktops
The upgrade to JRE 8 is recommended for EBS users, but some users may need to run older versions of JRE 6 or 7 on their Windows desktops for reasons unrelated to the E-Business Suite.
Most EBS configurations with IE and Firefox use non-static versioning by default. JRE 8 will be invoked instead of earlier JRE releases if both are installed on a Windows desktop. For more details, see “Appendix B: Static vs. Non-static Versioning and Set Up Options” in Notes 290807.1 and 393931.1.
What do Mac users need?
Mac users running Mac OS X 10.10 (Yosemite) can run JRE 7 or 8 plug-ins.  See:
JRE is used for desktop clients.  JDK is used for application tier servers
JDK upgrades for E-Business Suite application tier servers are highly recommended but currently remain optional while Java 6 is covered by Extended Support. Updates will be delivered via My Oracle Support, where you can continue to receive critical bug fixes and security fixes as well as general maintenance for JDK 6 for application tier servers.
Java SE 6 is covered by Extended Support until June 2017.  All EBS customers with application tier servers on Windows, Solaris, and Linux must upgrade to JDK 7 by June 2017. EBS customers running their application tier servers on other operating systems should check with their respective vendors for the support dates for those platforms.
JDK 7 is certified with E-Business Suite 12.  See:
References Related Articles
