A question that is frequently posed by E-Business Suite sysadmins is – “What patches should I apply to my environment?”
There are three ways to get a list of recommended patches for your EBS environment:
  1. EBS 11i and 12:  Use the E-Business Suite Patch Wizard
  2. EBS 12 only:  Search using the My Oracle Support “Patch Search” feature
  3. EBS 11i and 12:  Search using the My Oracle Support “Recommended Patch Lists” shortcuts
To learn more about all three options, see:
Option 1: Use the EBS Patch Wizard (recommended)
Within Patch Wizard is the Recommend/Analyze Patches function which will create a list or recommended patches.  To use this feature in Patch Wizard, first login to your Oracle E-Business Suite environment with a user that has the System Administrator responsibility.  Then, navigate to System Administrator > Oracle Applications Manager >Patch Wizard.
NOTE:  If you are not familiar with the Patch Wizard utility, you should learn
more about it.  The tool is provided with your EBS environment as part of Oracle Applications Manager.  It requires no additional installations to use.
You must first configure the Patch Wizard Preferences with a valid My Oracle Support account.  This configuration is a one time setup step.  Additional details regarding Patch Wizard and the initial configuration requirements are provided in the following My Oracle Support Note:
Once the initial configuration for Patch Wizard is complete, locate the Patch Recommendations Requests section in Patch Wizard as shown in the following figure.
Click on the Tasks button for Recommend/Analyze Patches .  After selecting the patch filter per your requirements, click OK and confirm the execution of the Recommended Patches request.  The output will display a list of recommended E-Business Suite patches with a status of Applied/Unapplied .
For additional details, please refer to Method 1 – Patch Wizard (EBS Support Recommended) section in the following My Oracle Support Document:
Option 2: Search My Oracle Support for EBS R12 patches
Another option for finding recommended patches is using the Patch Classification available from My Oracle Support.  First, login to My Oracle Support and go to the Patches & Updates tab as shown here:
In the Patch Search region, click on Product or Family (Advanced) as shown in the following figure:
Enter the Product, Release, Platform.  Then add Classifications by clicking the plus button as shown in the following figure:
Within Classification, check both Critical and Other Recommendations as shown in the following figure:
Now execute the search by clicking the Search button.  The search results will be then be displayed.  In the search results, the Classification column will indicate if the patch was Critical or Recommended.
For additional details, please refer to Method 2 – Patch Classification Search section in the following My Oracle Support Document:
Option 3: My Oracle Support “Recommended Patch List” shortcuts
At present, there are a couple of functional enhancements in the My Oracle Support development pipeline for Option 2, above.  These are being worked on right now; stay tuned to this blog for updates.
Until those enhancements are delivered, Option 3 is a tried-and-true method for getting a web-based listing of recommended patches.  The following links on My Oracle Support provide a listing of recommended patches for an Oracle E-Business Suite R12 or R11i environment.
First: login to My Oracle Support.  Once logged in, navigate to the Patches & Updates tab. Navigate to the Patching Quick Links region.  This region contains links to Recommended R12 Patches and Recommended R11i Patches:
After clicking one of the recommended patches links for either R12 or R11i, you have the ability to enter additional search criteria to narrow the results of the recommended patch list.  Search criteria include:
  • Maintenance Release,
  • Product or Product Family,
  • Platform or Language and
  • Updated in last “X” Days, Weeks or Months.
The search criteria for an R12 environment are displayed in the following screen shot:
For additional details, please refer to Method 3 – Legacy Search for Recommended Patches section in the following My Oracle Support Document:
A customer’s views
It’s sometimes interesting to hear from other members of the EBS DBA community who are wrestling with the same questions.  Check out the following articles by Barb Matthews (non-Oracle author):
Related Articles
(Special thanks to Yuko Saito in Oracle Support for her contributions to the article and My Oracle Support Document, How to Find E-Business Suite Recommended Patches (Note 1400757.1))
