X
The Latest Oracle E-Business Suite Technology News direct from
Oracle E-Business Suite Development & Product Management
Discoverer 11.1.1.7 Certified with E-Business Suite
Steven Chan
Senior Director
Oracle Business Intelligence Discoverer is an ad-hoc query, reporting, analysis, and Web-publishing tool that allows end-users to work directly with Oracle E-Business Suite OLTP data.
Discoverer graph screenshot
Discoverer 11g (11.1.1.7) is now certified with Oracle E-Business Suite Release.  Discoverer 11.1.1.7 is part of Oracle Fusion Middleware 11g Release 1 Version 11.1.1.7.0, also known as FMW 11gR1 Patchset 6.  Certified E-Business Suite releases are:
  • EBS Release 11i 11.5.10.2 + ATG RUP 7 and higher
  • EBS Release 12.0.6 and higher
  • EBS Release 12.1.1 and higher
Certified Platforms
Oracle Discoverer Release 11g R1 Patch Set 6 (11.1.1.7) is certified to run on any operating system for which Oracle WebLogic Server 11g is certified. For platform details, see:
References
Join the discussion
Comments ( 32 )
  • Floyd Thursday, June 6, 2013
    Steven,
    Safe to assume that the Discoverer certification does not include EBS 12.2?
    Thanks,
    --Floyd--
  • Steven Chan Thursday, June 6, 2013
    Hi, Floyd,
    EBS 12.2 isn't released yet, so, yes, this announcement only covers EBS 11i, 12.0, and 12.1 today.
    When EBS 12.2 is released, it's safe to assume that the latest Discoverer version will be certified with it.
    Regards,
    Steven
  • guest Wednesday, August 14, 2013
    Is Discoverer 10g certified with EBS R12? Or do we have to be on 11g in order to go to R12?
  • Steven Chan Wednesday, August 14, 2013
    Hello, Guest,
    Extended Support for Discoverer 10g ended in December 2011. All Discoverer 10g users should upgrade to 11g immediately, regardless of whether you're running EBS 11i, 12.0, or 12.1.
    It is safe to assume that future releases like EBS 12.2 will only be certified with Discoverer 11g.
    Regards,
    Steven
  • guest Monday, August 19, 2013
    Hello Steven,
    Could you tell me when premier support ends for this version of Discoverer? Is there a difference in support levels if Discoverer is used standalone or with EBS as a source? And is there an Oracle note on Support that I can refer to?
    Thanks for the help,
    Andy.
  • Steven Chan Tuesday, August 20, 2013
    Hello, Andy,
    All support dates are published in the Lifetime Support Policy documents available here:
    http://www.oracle.com/us/support/lifetime-support/index.html
    As you can see from the Middleware document, Discoverer 11gR1 has Premier Support to June 2014, and Extended Support to June 2017.
    EBS support dates do not affect Discoverer support dates. For more details, see:
    https://blogs.oracle.com/stevenChan/entry/on_apps_tier_patching_and_support_a_primer_for_ebs_users
    Regards,
    Steven
  • guest Friday, August 23, 2013
    Hello steven
    can you kindly explain or point to a doc that explains the improvments for discoverer regarding to version 11.1.1.4 or 6
    regards
  • Steven Chan Friday, August 23, 2013
    Hello, Guest,
    These patchsets are collections of bug fixes. They don't deliver any new functionality. You can review the README or the release notes to see whether there are any lists of bugs. If not, you can log a Service Request against the Discoverer product to have a specialist help you out with that.
    Regards,
    Steven
  • guest Saturday, August 31, 2013
    Hi Steven,
    From the Oracle Life Support Policy, I see that the Premier Support for Discoverer 11gR1(11.1.1.x) ends in June 2014. Does it cover all three products: Discoverer Administrator, Discoverer Desktop, and Discoverer Plus?
    Also, we are planning to upgrade from 10g (Desktop & Plus) to 11g (Plus). Is it beneficial to get 11g Desktop as well? What are the differences between 11g Desktop vs. Plus?
    Thank you very much!
    JL
  • Steven Chan Tuesday, September 3, 2013
    Hi, JL,
    Yes, all Discoverer components are covered by the Premier Support date that you noted above.
    I would recommend that you upgrade all of your older Discoverer components to the latest 11g level.
    I'm in E-Business Suite Development and don't have much visibility into Discoverer functionality. You can log a Service Request against the Discoverer team to get help with your question about the differences between releases.
    Regards,
    Steven
  • JL Tuesday, September 3, 2013
    Hi Steven,
    Thank you for your response. I have another question.
    From the Oracle Fusion Middleware 11g Release 1 (11.1.1.x) Certification Matrix, it says Discoverer Administrator and Discoverer Desktop 11g R1(11.1.1.2+) is certified with Windows 7 32 bit.
    Does 11g R1(11.1.1.2+) covers 11.1.1.2 and all versions above? We want to make sure 11.1.1.7 is certified with Windows 7 32 bit before we upgrade from 11.1.1.3 to 11.1.1.7.
    JL
  • Steven Chan Wednesday, September 4, 2013
    Hi, JL,
    Yes, that would be my interpretation.
    I'm in EBS Development, so I can't speak for the Discoverer team. If you wish an authoritative answer, you should follow up with a formal Service Request against the Discoverer product itself.
    Regards,
    Steven
  • guest Thursday, September 5, 2013
    Hi Steve,
    We are already at latest 11.1.1.7 Discoverer with EBS. Considering desupport June 2014 of 11gR1 is there a future 11gR2 Discoverer on the horizon or is Oracle waving the magic wand to force customers to OBIEE.
    Randy..
  • Steven Chan Thursday, September 5, 2013
    Hi, Randy,
    The Discoverer Statement of Direction is posted here:
    http://www.oracle.com/technetwork/developer-tools/discoverer/overview/index.html
    Here's the direct link:
    http://www.oracle.com/technetwork/developer-tools/discoverer/overview/discoverer-sod-jan2009-132849.pdf
    Discoverer 11g is the last major release for this product line. As you can see from that document, customers are being encouraged to switch to OBIEE.
    Regards,
    Steven
  • Lynda Tuesday, September 24, 2013
    Hi Steven
    Given that EBS 12.2 is now released, we would like to know when Discoverer will be certified with it.
    best
    Lynda
  • Steven Chan Friday, September 27, 2013
    Hi, Lynda,
    Discoverer 11.1.1.7 is certified with EBS 12.2. See:
    "Using Discoverer 11.1.1 with Oracle E-Business Suite Release 12.2" (Doc ID 1380591.1)
    Regards,
    Steven
  • guest Friday, October 11, 2013
    Hi, Steven.
    We are upgrading Discoverer 10g to 11.1.1.7 and integrating it with EBS and with OAM for authentication.
    We installed Discoverer Administrator and Discoverer Desktop 11.1.1.3.
    However, I cannot find any information on how to integrate Discoverer Administrator and Discoverer Desktop with OAM.
    Do they have a feature of integrating with OAM for authentication or do we have to keep using local EBS login?
    Regards,
    Anatoly
  • Steven Chan Monday, October 14, 2013
    [Reposting - cleaning up editing artifacts]
    Hi, Anatoly,
    Integration with OAM depends upon the interception and redirection of middle-tier requests to OAM. Client/server tools generally bypass the middle-tier entirely and attempt to connect directly to the database.
    I don't believe that the two client/server Discoverer tools that you mentioned support OAM integration. You can get an authoritative verdict by logging a Service Request against Discoverer Support.
    Regards,
    Steven
  • guest Tuesday, November 12, 2013
    Hi Steven,
    I appreciate you work in EBS Development, but just wanted to post an update for others.
    We use Discoverer 11g (11.1.1.7.0) with an in-house developed Oracle Forms application, and have been trying to get a statement from Oracle for many months now on the future of Discoverer as the end of Premier Support for 11gR1 approaches next year, but so far all we have had is that a new Statement of Direction is "imminent"...and that was in late August!
    I personally can't believe that a product is coming so close to the end of Premier Support and we've have no Statement of Direction more recently than January 2009...
    I would also say that in that Statement of Direction it certainly lists some of the advantages of switching to OBIEE, but to me the Recommendations section at the end states that "Existing Discoverer customers can continue to use Discoverer with the assurance of Oracle‟s Lifetime Support Policy, as well as with the continued planned enhancements and integration with future releases of Oracle Fusion Middleware and Oracle BI EE." and that "Existing customers are strongly encouraged to upgrade to Oracle BI Discoverer 10gR2 10.1.2.3 and to migrate to web deployment to take advantage of the many new exciting and powerful enhancements in this version and to get the best support benefits available.".
    Anyway, despite no new Statement of Direction, I see there is a single statement buried in the document about extended Premier Support for FMW 11gR1 (Doc ID 1585582.1) that lists Discoverer 11gR1 as an exception with the comment "Customers are directed to move to Oracle Business Intelligence 11g", so I guess that's our answer.
    It would be useful if Oracle could have released that as a new Statement of Direction along with information on switching and also additional license requirements for that switch...
    Regards,
    Grant
  • Steven Chan Tuesday, November 12, 2013
    Hi, Grant,
    Yes, as you've correctly noted, I'm with EBS Development and my influence over sister products such as Discoverer is limited. I have passed on your feedback to Discoverer Product Management but would encourage you to log Service Requests against Discoverer directly to ensure that your concerns are officially communicated.
    You may also wish to contact your Oracle account manager and ask him/her to escalate this to Discoverer Product Management.
    Regards,
    Steven
  • guest Wednesday, June 4, 2014
    Hi, I have an installation question.
    If I install Discoverer 11.1.1.7 do I apply the one off patch 9387227 for 11.1.1.2 or skip it because I'm going to 11.1.1.7.
    Is it included in the 11.1.1.7 patch? I don't see it on the list for 11.1.1.7 bug fixes.
    1. Install 11.1.1.2 + one off 9387227
    2. Install 11.1.1.7
  • Steven Chan Wednesday, June 4, 2014
    Hello, Guest,
    We can provide general conceptual guidance here, but I'm afraid that this blog isn't the best place to get technical support for specific questions like the one that you're working through.
    Your best bet would be to log a formal Service Request via My Oracle Support (formerly Metalink) to get one of our specialists engaged.
    Please feel free to forward your Service Request number to me if it gets stuck in the support process for some reason.
    Regards,
    Steven
  • guest Wednesday, July 9, 2014
    Hello Steven,
    Oracle released that discoverer is no longer supported for R12 or its Premier support is ending. Is that correct statement? 11.1.1.7 is Terminal release. What does it mean?
    Are all customers forced to upgrade to OBI EE?
    reddy
  • Steven Chan Tuesday, July 15, 2014
    Hello, Reddy,
    EBS users should evaluate whether OBIEE meets their requirements, but we do not expect a forced upgrade while EBS includes hard dependencies on Discoverer.
    We're still working out the language for a formal statement of support for Discoverer for EBS users. In the meantime, until that statement is published, it is reasonable to expect that for EBS users will continue to receive patches for critical Discoverer issues through the Extended Support periods of the respective EBS releases.
    The preceding is intended to outline our general product direction. It is intended for information purposes only, and may not be incorporated into any contract. It is not a commitment to deliver any material, code, or functionality, and should not be relied upon in making purchasing decision. The development, release, and timing of any features or functionality described for Oracle’s products remains at the sole discretion of Oracle.
    Regards,
    Steven
  • Migs Isip Thursday, January 22, 2015
    Hi Steven,
    We're looking to implement Oracle Discoverer to our company's end-users for data downloading. Do we need to purchase a license or we can just use the downloadable installer from Oracle Downloads page? users just need to download data, no other functions will be used.
    thanks!
  • Steven Chan Thursday, January 22, 2015
    Hi, Migs,
    You will need to purchase a license for Discoverer if you wish to use it for reporting.
    Regards,
    Steven
  • guest Saturday, June 20, 2015
    Hi STeven,
    We working on Project to transform Oracle EBS R12.1.3 to Linux 5.6 from Oracle Solaris.
    Currently we are on Oracle BI Discoverer Viewer Version 11.1.1.4.0.
    After migrating the discoverer EUL to new OS, are all existing report transferred to new version or we need redevelop the report.
    Please advice.
    Regards,
    Deb
  • Steven Chan Monday, June 22, 2015
    Hello, Deb,
    Changing server-based operating systems for either the E-Business Suite or wherever you're running your Discoverer Server instance will not affect any of your existing Discoverer workbooks.
    You should upgrade to Discoverer 11.1.1.7 at your earliest convenience.
    Regards,
    Steven
  • Chuck Monday, August 10, 2015
    Steven -
    We are running e-Business Suite 12.1.3 with Discoverer 11.1.1.7 along with IE11 and Windows 7 64-bit on the desktop. Specific to Java on the desktop, we need to run Java 1.6.0_43 on our clients due to other critical application compatibility. This version of Java looks to be supported with e-Biz but I cannot tell if it is supported with Discoverer. If it is not supported, do you know of any known issues using this version of Java with Discoverer? We cannot upgrade to Java 1.7 at this time.
    Thanks,
    Chuck
  • Steven Chan Monday, August 10, 2015
    Hello, Chuck,
    JRE 1.6.0_43 was released in March 2013. I don't recall hearing about any compatibility issues with Discoverer, but that seems a long time ago now. The chances are good that that combination is fine.
    Remember that I'm part of the E-Business Suite division, so if you need a definitive answer on compatibility between Discoverer and JRE 1.6.0_43, you would be best-served by a formal Service Request against Discoverer.
    Regards,
    Steven
  • Richard Friday, December 20, 2019
    Does Discoverer 11.1.1.7.0 certify with EBS R12.2.9?
    if does not,if is there any plan to certify?
  • Elke Phelps (Oracle Development) Friday, December 27, 2019
    Richard,
    - Premier Support for Discoverer 11gR1 ended June 30, 2014.
    - Extended Support for Discoverer 11gR1 ended June 30, 2017.
    See the following for EBS Support Implications for Discoverer:
    https://blogs.oracle.com/ebstech/ebs-support-implications-for-discoverer-11gr1-in-june-2017
    Regards,
    Elke
Please enter your name.Please provide a valid email address.Please enter a comment.CAPTCHA challenge response provided was incorrect. Please try again.
