How to connect to GoldenGate with IDCS Federation using adminclient
August 27, 2024 | 3 minute read
Adriano Tanaka
Senior Cloud Engineer
Text Size 100%:
Oracle Identity Cloud Service (IDCS) offers a comprehensive suite of identity and access management (IAM) capabilities that can significantly enhance the security and efficiency of the organization's operations like Authentication & Authorization, SSO, Centralized Identity Management, Integration capabilities with all non-oracle and oracle applications, scalability & Flexibility and many more.
In this post, I will guide you on how to log in to the adminclient using the TOKEN parameter with OCI GoldenGate 23ai. I assume you already have your OCI GoldenGate deployment set up with IAM authentication.
1. Locate the Application:
   - Navigate to Identity > Domains > YOUR DOMAIN > Oracle Cloud Services.
   - Search for the first part of your deployment Console URL to find the application.
2. Assign the User:
   - In the application, assign the user to it.
3. Log in to OCI:
   - Log in to OCI with the user that will be used in adminclient.
   - Go to My Profile under the user icon in the top right corner.
4. Generate the Access Token:
   - Since the user is added to the GoldenGate application, they can see the application in My Access Token > Invoke other APIs.
   - Select the application name, specify the token lifetime, and download your token.
5. Copy the Token:
   - Open the downloaded .tok file and copy the content (it should be a very long string).
6. Connect Using adminclient:
   - In adminclient, use the following syntax:
connect https://deployment_url TOKEN !
   - Paste your token.
Adriano Tanaka
Adriano is a Senior Cloud Engineer in Brazil, he works with Oracle DB, Exadata, GoldenGate and IaaS, Oracle ACE Alumn with a strong community presence.
Show more
Previous Post
Behavior Changes in GoldenGate 23ai
Volker Kuhr | 6 min read
Next Post
Announcing GoldenGate on Azure Certifications
Nick Wagner | 3 min read
Oracle Chatbot
Disconnected
